Material to laminate a built-up shed / barn door, AND hinges
   / Material to laminate a built-up shed / barn door, AND hinges #1
tshep
Gold Member
Richmond, VA
BX23 MLB
I need suggestion!
I am in a HOA (!@#$%^&*) area, and need a no/low maintenance surface for shed doors - the 2 will be 100 x 100. split. (The hole is big enough for my tractor on its trailer.)
I envision a light frame from 2x2 or aluminum angle, filled with foam board for light, rigid fill, backed by thin plywood. (Maybe faced by that plywood instead, per laminate.) I will then 'frame' them on the face with white PVC trim for rigidity, strength, and view in a classic framed and bisected 'X'.
I seek a face material (and suggested source) that will require no maintenance, a plastic or affordable aluminum sheet.
I would prefer a light gray, without 'board' pattern, so far...
Hinges?
They will have siding 'J' extending the doorframe depth (I could notch), and need to go full '180' open (so door depth will not block opening) to clear wheels coming into shed.
Thanks folks!
   / Material to laminate a built-up shed / barn door, AND hinges #2
Here's 4x8 sheet in 1/4 or 1/16" - use this and trim with azac oon bith sides and build your X on both sides for rigidity and you can extend the azac 2" over on one side and top/bottom to get the 50x100"
Still concerned this may be wobbly / flex a lot - have you considered sliding hanging doors instead of hinges (barn door style)?
   / Material to laminate a built-up shed / barn door, AND hinges #3
You can also buy PVC (think Azac) in 4x8 sheets of various thickness. I did then when needing to wrap several posts, just bought a sheet of 1/4" material and ripped what I needed from it. Has an advantage over aluminum or other panels, because you can PVC cement bond between the trim and panel.
Went for big overhang all 4 sides, 'bird box' returns on gables - it will well match existing garage in view. Eaves will be below door tops.
Thanks for product names - I will pursue!
   / Material to laminate a built-up shed / barn door, AND hinges #5
Pictures would be great - please!
   / Material to laminate a built-up shed / barn door, AND hinges #6
PVC sheet: HD says none within 100 miles.
Bruce
   / Material to laminate a built-up shed / barn door, AND hinges #7
   / Material to laminate a built-up shed / barn door, AND hinges #8
Contact your local metal supplier for aluminium "propeller plate"
This stuff is thin, light, easily fabicated and comes in the usual 8X4' sheets. It can be bonded with polyurethane and/or fixed with sheet metal screws and is easily painted with etch primer and any top coat
I have used it on several jobs - especially in boats and wish I had known about it years ago,
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
BUSH HOG DISC (A58214)
2018 John Deere 2025R Tractor - 647 Hours (A56435)
2018 John Deere...
(INOP) RHINO 1310 ROTARY CUTTER (A52708)
(INOP) RHINO 1310...
2007 Heil Heavy Duty Aluminum Tank Trailer (A56435)
2007 Heil Heavy...
2012 MACK CHU613 (A58214)
2012 MACK CHU613...
