Preserving diesel fuel in transfer tank
   / Preserving diesel fuel in transfer tank #12
I have a 500 gallon farm tank beside the shop that I generally keep full (when I have enough funding to fill it with off road diesel hovering around 4 per gallon here that is always expensive)... I never use it all, always has some fuel in it. I regularly drain off what collects in the bottom of the tank and I always use a biocide like Powerservice Bio-Kleen. Easy to tell what a genuine biocide is by the labelling. Any biocide will have the required Federal hazardous substance labelling on the bottle.
Neither of my tractors are High pressure common rail like the new ones are and the new T4 units are very sensitive to any water or contaminates in the fuel and they can cause very expensive issues as has been noted in some threads on here.
Have no idea what MF uses for fuel filtering but I do know what Kubota uses and at least on my units, it ain't much (spin on primary
and a fuel bowl separator pre injection pump so I added a fuel polishing unit pre spin on filter (Racor style) with a clear bottom bowl that I can drain off any accumulated stuff that comes out of the fuel tank (including any water or debris).
I do know that the standard Kubota spin on filter has a pass rate of 80 microns and the fuel bowl with it's brass screen will pass small pebbles...lol
The fuel polishing unit I added 2 both of mine, the spin on filter with the clear bottom has a pass rate of 30 microns plus it's a water blocking (stripping filter) that removes and deposits any water in the clear bottom drainable bowl.
Did a thread under Kubota owning-operating you might want to look at.
I do know that Kubota is now adding polishing units to their T4 final tractors from the factory but on what units or sizes, I have no idea.
I modified mine because the Racor style units aren't that expensive and they give an added insurance against injection pump failure. Have one on my diesel pickup truck as well.
   / Preserving diesel fuel in transfer tank #13
Yes there can be.
You get the 'diesel bug' algae, you'll wish you added a biocide to your fuel. been there, did that and it's not a cheap date to rectify.
Just because some 'elixier' additive says it prevents algae growth don't mean squat of it don't have the Federal Government attached MSDS labelling attached to the bottle.
Keep in mind that biodiesel (B20 or better) is the most susceptible to algae growth. The Bio part likes to grow slime and it's the slime that destroys the injection system.
No bio diesel here. They can shove that stuff IMO.
   / Preserving diesel fuel in transfer tank #14
I’ve been driving my MF135 Deluxe for about five years… the first three years I lifted countless 5 gallon Jerry cans to fuel up… then I got a deal on a 33 gallon transfer tank…
the old Fill-Rite pump works great (the tank came off a 1984 Nissan pickup which was used at a local airport so I’m guessing the tank is about 30 years old…)… first thing I did was install a particulate filter between the pump and hose… filled up with red diesel and poured some two stroke oil in the tank then ran the nozzle in a loop to the tanks fill port… I let the pump run for about ten minutes to mix in the lubricating oil and also to clean any gunk out of the hose…
Been working great for a litt over a year now…
THEN I DID IT… went and bought a new tractor (Kioti 2610 HST)… the dealer suggested I purchase a dedicated, plastic fuel container so I can be sure to alway have fresh, clean fuel in my new toy… “New engines are expensive” he says… and the warranty doesn’t cover owner abuse (read: “bad fuel”)…
Which got me to looking into how modern ULSD “deteriorates” in storage… condensation inside the tank breeds “diesel bugs” which can wreak havoc on my new tractors fuel system… or so I’m lead to believe…
i don’t drive the Massey a lot.. didn’t go through an entire 33 gallon tank this last year… I’ll probably use more with the new tractor but i don’t want to screw it up… and I REALLY don’t want to go back to schlepping 5 gallon fuel cans…
At this point I’m seriously considering adding a second “water” filter in the circuit then recirculating fuel through the tank from time to time to keep the condensation out and the bugs trapped in a disposable filter…
Am I being overly paranoid?
I've never ever had a water in diesel problem in around 40 years driving diesel cars and tractors since 2004.
   / Preserving diesel fuel in transfer tank #15
Just as an aside, I would not consider bad fuel to be “owner abuse” that would void a warranty. You could do all that you plan to do, then buy fuel somewhere that, as far as you know, is good, but turns out to be bad.
And would still not be covered under warranty. Bad fuel from a known source could be responsible for damages. like a gas station gets a new fuel tanker but is contaminated with water. the station would be responsible for damaged not the vehicle or equipment warranty.
   / Preserving diesel fuel in transfer tank #16
Be patient, if you leave it sit with a partial tank you will at some point. Diesel that was cracked 40 years ago and modern ULSD diesel are 2 different things.... and in some areas, refiners are adding bio diesel and not telling you as well. Bio is the culprit as it promotes algae growth when combined with condensation that forms in a partial tank of fuel during ambient temperature changes.
   / Preserving diesel fuel in transfer tank #17
If you can, fill your tractors with the engine turned off and let the tractor sit a spell.
When you fuel, you stir up all kind a crap from the bottom of the tank.
Well… could be I’m cryin‘ before I’m even hurt…
I just went to the barn to inspect the transfer tank… to see exactly what I’m dealing with…
reading the particulate filter (# F4010PMO) it’s rated for: dirt, rust and microbes… are microbes the diesel bug I’ve been readin about?
it’s a 10 micron filter… is this gonna keep all the bad juju outta my fuel system? (Except water… I’m still going to place a water filter on The pump…)
   / Preserving diesel fuel in transfer tank #19
It isn’t hard to spot bacterial contamination in diesel fuel. You will see black slime in the fuel filter. Yes, microbes=bacterial contamination and a 10 micron filter should work fine.
Home heating fuel tanks that are installed outside of the house are the biggest troublemakers in this regard. You have to have some water in the tank and simple condensation provides the water. It’s not usually a problem with tanks inside the house or buried tanks.
My experience is with home heating oil tanks. I still keep my diesel fuel in 5 gallon cans. My advice is to add a biocide to your tank once a year or so and keep an eye on the fuel filter on the tractor for black slime.
   / Preserving diesel fuel in transfer tank #20
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2016 HINO 195 16FT BOX TRUCK (A54607)
2016 HINO 195 16FT...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
2016 GMC 2500HD SERVICE TRUCK (A51406)
2016 GMC 2500HD...
