Would this be worth the 350 aud? It's a McCormick 624
   / Would this be worth the 350 aud? It's a McCormick 624 #1
Boganism
Member
None
   / Would this be worth the 350 aud? It's a McCormick 624 #2
I have no clue what 350 aud is but other than needing new paint that tractor looks pretty decent.
350 aud is Australian dollar, since our stuff is seemingly way overpriced
   / Would this be worth the 350 aud? It's a McCormick 624 #4
Does it run? What do the fluids look like? Do you enjoy fixing things up?
   / Would this be worth the 350 aud? It's a McCormick 624 #5
If it starts then I say yes.
350 AU = $220.26 USD. The tires are worth more than that
   / Would this be worth the 350 aud? It's a McCormick 624 #6
If you enjoy restoring stuff it Definitely seems like it should be worth a lot more than $220 USA dollars.
   / Would this be worth the 350 aud? It's a McCormick 624 #7
She's stood outside for so long that the tarp has rotted right off of it. Good to see that the muffler has a cup on it...but what about the intake? If water got into the engine, it would probably need a complete rebuild. If nothing else, the value in used steel is high right now. Let us know what you do...
   / Would this be worth the 350 aud? It's a McCormick 624 #8
That looks like a Gem to restore ! It almost looks like a newer Radiator hose ? Hopefully it was not over heated ? If I had the time I think this would be a great project . Good Luck and keep the pictures coming !
   / Would this be worth the 350 aud? It's a McCormick 624 #9
Has a D206 German Diesel, used in many much newer IH tractors up to the 3230 in the 1990s.
German built tractor, solid. I can't tell from the photos, but Agri-matic versions had a clutchless shuttle/power shift unit, that may or may not work. Regular dry clutch and 8 speed box still there.
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
96" X 53' FLATBED TRAILER (A52706)
96" X 53' FLATBED...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2016 John Deere 326E (A47477)
2016 John Deere...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2015 Volvo VNL 64T (A53473)
2015 Volvo VNL 64T...
