What did you do for your tractor today?
   / What did you do for your tractor today?
Bolted the little rubber bumpers on the new fancy seat suspension unit installed last week.
Project complete... Now I'm looking at the treadle pedal with bad intent. ;)
   / What did you do for your tractor today? #12
I'm about half way through the process of making a second step for my 3039R. Pics to come when/if my scavenging works.
Welded a chain hook onto a 1.25" bolt head so I can pull my road drag.
   / What did you do for your tractor today? #14
New battery. Added fuel. Hosed it off. Did experiment trying to eliminate floppy bucket cylinders.
Been working on the gauge wheels for the 84" BH landscape rake. Most pieces ready to weld up and bolt on.... I have been trying to do something to keep the attachment from digging too deep when smoothing out the gravel on my driveway - Pics soon
New attachment from Titan.
Receiver hitch for moving the trailer around etc
Of course anything SSQA works for the Kubota also
I ordered a SSQA grapple without forks. Cheaper without forks plus it was on sale from Titan. I have an old set of 42" forks lying around that should work.
   / What did you do for your tractor today? #19
Had the 494 loaded with rimguard for another 1600lbs
1600 pounds ! That is no small change. What does the tractor weight before the fill?
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2017 PETERBILT 579...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
Case Axial-Flow Combine Wheels NO RESERVE (A55301)
Case Axial-Flow...
2020 FREIGHTLINER DEBRIS BUCKET TRUCK (A51406)
2020 FREIGHTLINER...
KING CUTTER 6' FINISHING MOWER (A54756)
KING CUTTER 6'...
