tractor - type Shibaura Model S-070 Compact Tractor, LE752A.
   / tractor - type Shibaura Model S-070 Compact Tractor, LE752A. #1
pulec
Hi all, I would like to kindly ask if you might know where to get one broker part to my tractor - type Shibaura Model S-070 Compact Tractor, LE752A. I need injection pump because is KO.
I guess these tractors were sold under the brand in Europe/US as New Holland as well but don´t know the particular type. Any help please
   / tractor - type Shibaura Model S-070 Compact Tractor, LE752A. #2
The Ford 1100s have that same engine. You can get an exploded parts diagram from the Messicks website with Ford part numbers you can search for but it doesn't appear that any of them are available through Messicks. You may be able to find one but I would be really surprised if you are able to locate a new old stock one as I'm fairly certain that they are no longer being produced for a 2 cylinder tractor that was last built in the early 80s by a now defunct company. You may be able to find a used unit from a junkyard as there are junk yards that specialize in older gray market Japanese tractors, but you are taking a chance that that unit is in better shape than the one you've got.
I suggest that you send the unit you have off to an injection pump rebuilder. Many of the internal parts are common to multiple units including the more common three cylinders and oftentimes a rebuilder will be able to repair your pump.
MTGreen thank you very much, I am trying to find it on Messicks but I am not able :/ could you help me please? :) I would love to find the spare part number .... THANK YOU
   / tractor - type Shibaura Model S-070 Compact Tractor, LE752A. #6
Not sure what the problem is but why not find a local Diesel pump service/repair shop which should be able rebuild your current pump?
If that's not an option, a new pump SBA131016911 for US $ 581.52 may or may not solve the problem?
  • New Holland 1100 - 2 CYL COMPACT TRACTOR(01_79 - 12_82) Parts.pdf
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2018 Caterpillar...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
