BX23 Cream colored hydraulic fluid after 2 exchanges
   / BX23 Cream colored hydraulic fluid after 2 exchanges #11
found my water source.
The SUD2 spout had failed, and let the clear liquid into my 'trusted' can.
So no machine problems, strictly system 'operator' failure
You left a 5gal but of oil out in the rain? That's an expensive mistake.
No, it was in a rubbermaid suburb 'closet', but got me none the less!
Got the loader cleared - opened all the hoses, drained the cylinders and 'rolled' the loader with a chain, carefully, so everybody got a chance to be the low point.
Not looking forward to doing the backhoe!
6 cylinders, no common pairs...
BH messed up my nice amber fluid.
I blew out the feed/return lines as I hooked up.
Then did the 3 easy cylinders, 2 stabs and the bucket. Lifted the BH with stabs, and then as I rotated the bucket to install the BH, muscle memory kicked in and I used the dipperstick - arg!!
(I am amazed how much more fluid is in the cylinders, but think of soups cans - cans - when the rod is extended.)
Next I did the dipperstick cylinder, and when I purged the lines I was back to cream - amber cream, but cream none the less.
Hoping to go to the valves and blow out the boom and swivel from there - cylinders just too hard to get to easily.
2015 Ford F-150 Ext. Cab Pickup Truck (A55788)
2015 Ford F-150...
CFG Industrial H15R (A53316)
CFG Industrial...
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
Kubota KX080-4 Excavator Cylinder (A50775)
Kubota KX080-4...
2017 Ford F-550 4x4 Altec L37M 37ft. Insulated Material Handling Bucket Truck (A55788)
2017 Ford F-550...
GooseNeck Trailer (A52377)
GooseNeck Trailer...
