Kubota KX033-4 Thumb will not retract
   / Kubota KX033-4 Thumb will not retract #1
m7040
Elite Member
Frederick maryland
Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
The thumb will clamp down but will not retract. Wondering if someone could help with best way to trouble shoot?
   / Kubota KX033-4 Thumb will not retract #2
Do you have a splitter valve for the thumb that could have gotten bumped ?
On excavators it is not done with splitter valves
   / Kubota KX033-4 Thumb will not retract #4
If that machine has both 1 way and 2 way flow to the auxiliary lines make sure you’ve got 2 way selected. If it inadvertently got 1 way flow selected theirs your issue
   / Kubota KX033-4 Thumb will not retract #5
Reverse the lines ,this will check if it’s fittings or valve or cylinder
   / Kubota KX033-4 Thumb will not retract #6
This is the first thing I'd check too.
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
FAKE (A52472)
FAKE (A52472)
2015 BIG TEX FRAC WATER TREATMENT TRAILER (A55745)
2015 BIG TEX FRAC...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
30pc. 16ft.x 3ft. Black Metal Roof Panels (A53424)
30pc. 16ft.x 3ft...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A55851)
2015 Kubota...
