Massey Ferguson 232 loader on a 235 Massey Ferguson tractor with a PTO driven pump,the up and down lift on the loader works great, but the tilt leaks,
   / Massey Ferguson 232 loader on a 235 Massey Ferguson tractor with a PTO driven pump,the up and down lift on the loader works great, but the tilt leaks, #1
Michael Butcher
Massey Ferguson 235
Massey Ferguson 232 loader on a Massey Ferguson 230 tractor with a external PTO driven pump, lift on the loader works great,but the tilt leaks down rather quickly any advice
   / Massey Ferguson 232 loader on a 235 Massey Ferguson tractor with a PTO driven pump,the up and down lift on the loader works great, but the tilt leaks, #2
If there are no external leaks then it is likely the control/spool valve that is allowing the cylinder to leak down. Sometimes it can indicate the piston seal is leaking. If you do a google you will find a instructions to determine which it is.
Hope this helps.
(APPROX 15) 2" X 6" X 68" TUBING (A54756)
(APPROX 15) 2" X...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A55852)
2003 Pierce Tilt...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
28" X 5' BACK BED FOR RTV (A54756)
28" X 5' BACK BED...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
White Metal Roof Panels (A55758)
White Metal Roof...
