Truck mounted, quick detach, round bale mover.
   / Truck mounted, quick detach, round bale mover. #1
jwmorris
This project started with me coming across this unit a couple months ago.
I already did a dump trailer and have been working on the farm truck, after rebuilding the AC compressor I decided to make a hay mover for it that I could easily remove when not in use.
I came across this double acting cylinder with a bent shaft and decided it looked close to what I was looking for.
After straightening the shaft, I installed new o-rings and seals. I have a bunch of short -8 Aeroquip 3000 psi lines but the hydraulic unit uses metric fittings. So I just mated the pump side of their fitting to AN fittings I had in the drawer.
A couple gallons of fluid and a battery and I now have that part ready to go.
Aside from having both hydraulic connections at the same end this cylinder also has a pin off the face that can be depressed with an adjustable stop, on the shaft, I could use to adjust the stopping angle of the bale going up.
   / Truck mounted, quick detach, round bale mover. #2
Use gooseneck hitch and a 12 v winch. I wouldn't fool with hydraulic.
   / Truck mounted, quick detach, round bale mover. #3
Looks good, and I admire the "operating room" looking shop!😁
Keep us updated with the results especially the dang near free hydraulic unit.👍
   / Truck mounted, quick detach, round bale mover. #4
Sure do! I have a dirt floor and a leaky ceiling. 😝
Yeah, $160 used to be expensive but now I can’t fill up an empty truck for that.
I spaced the ram 3/8“ above the 2x3 box tube, I am going to use between the rear of the bed and the gooseneck hitch and cut a cardboard template.
Then made another template off of that one from a hunk of wood on the floor, for my pantograph machine to follow.
A corner “drop“ from my roller project was just the right size. The pantograph makes short work of clean up. These are “as cut”.
Cut two, 1/2” plates instead of one 1” because I had the right size drop and in the end a single 1/2” plate would do the job but two fit the clevis on the cylinder.
For the rear pivots I use 3/4” plate and Flanged oillite bushings.
I wish I had made the pantograph in my early days, sure would have saved a lot of grinding wheels.
My hitch came in and I chopped it up.
Then poked around through my “junk”, as Mrs. Morris would call it and found a bit of 1/2” plate and some 3/16 wall rectangle box tubing.
   / Truck mounted, quick detach, round bale mover. #8
More info on the pantograph machine please
I made this video of it a few years ago that is worth a thousand words.
The most important parts are that the arbor that drives around the template must be true. Motor shafts are good but it’s got to be perfect or —————- on your template turns into ~~~~~~~~ on the steel. The second is that the arm swing across the work area and remain the same distance above the work piece.
706075 LOT NUMBER 81 (A53084)
706075 LOT NUMBER...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
J and L Cargo Express Shadowmaster Enclosed Trailer (A53472)
J and L Cargo...
Towable Orchard Sprayer (A51691)
Towable Orchard...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
