Mahindra 6075 Joystick Part
   / Mahindra 6075 Joystick Part #1
BCL12
Texas
Mahindra 6075
The is from the front-end loader joystick and is the Axis that seems to be a weak point based on how many are on order with Mahindra. The only solution Mahindra offers is to replace the entire joystick kit. I don’t understand why one has to buy a $345.80 lever kit when all that is needed is a much smaller part, aggravating!!! Could a much stronger material been chosen to manufacture the Axis like steel, jus sayin, I would have thought so!!!
Also if anyone else has dealt with this and possibly had a machine shop make a stronger version, please point me to them? Photos are of the broken axis from the joystick.
   / Mahindra 6075 Joystick Part #2
That doesn't look all that complicated. Mostly a matter of locating a nut of that size and thread. A couple proper size set collars or sections of pipe. Set it all up and weld it together. I'm sure I could do all that myself, so there should be no reason why any qualified weld shop couldn't duplicate that. And make one twice as strong at that.
That's a very simple approach, thanks for the suggestion.
2011 MERCEDES-BENZ S-Class Sedan (A53424)
2011 MERCEDES-BENZ...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A55301)
2016 KBH...
2844 (A54757)
2844 (A54757)
Duetz Power Unit (A50120)
Duetz Power Unit...
30006 (A53424)
30006 (A53424)
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A54313)
2019 KENWORTH T680...
