New (to me) 2019 XJ2025H
   / New (to me) 2019 XJ2025H #1
DoubleJ1929
LS XJ2025H
Lurked for a bit but believe this is first post on TBN. Just picked up a 2019 XJ2025H with FEL and BH with 135 hrs. No picture, sorry..
Couple of newbie questions.... I do have some uneven ground it will play on so want to add fluid to tires and potentially spacers. Was surprised to see valve stems on inside of rear tires. You DIY's able to maneuver lines to get fluid in while tire still on tractor or did you have to remove? And spacers... Look through forum it looks like Bro-Tech was the favorite. Is this still the case? Any challenges or concerns to add? 2"? 3"?
Thanks all!!
   / New (to me) 2019 XJ2025H #2
If your planning on adding spacers, and Bro-Tech are very good spacers, you will need to remove the tires. Fill the tires then.
Thanks for quick reply Citydude!! Tire off for adding spacers for sure. But was hoping to fill while on tractor for handling purposes and it looks like it is easier when you are using the tractor weight to help? That's my so called knowledge base after a couple youtube video's. lol
Interested on thoughts of front spacers as well. Will the 1.5" offered make a appreciable difference?
OK... Typical of a newbie I guess I jumped the gun.. I am 3rd owner and was told tires were not filled. Just checked and they actually are (first owner must of had them done) with a dark fluid. Assuming Beet juice.
So with that I think I will order 3" spacers for the rear. Still question if the 1.5" in front is a good idea or not?
   / New (to me) 2019 XJ2025H #5
Some do add spacers to the front however lots more do not. With the front axle able to pivot on a center pin the front spacers will do little good.
I had 6" spacers on the rear of an L3400 that i used for contract mowing with filled rear tires. It stuck on the side of hills like a tick. Lol
Thanks again for the thoughts and reply Citydude. 3" spacers ordered and leaving the front end alone.
   / New (to me) 2019 XJ2025H #8
Welcome to the group. Our little XJ has worked out great for us and I hope for you too. There is a member here who hasn't posted in while but has a some good videos on YouTube with his XJ. JIMeRIG is his handle there.
   / New (to me) 2019 XJ2025H #9
and enjoy the forum!
Enjoy your LS our is a great work horse.
Thanks for the welcome all. And I have seen those youtube videos. Found all I could on the XJ before buying.
2000 OSHKOSH MILITARY M1070 TRUCK (A51243)
2000 OSHKOSH...
2007 Toyota Camry (A50324)
2007 Toyota Camry...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
2023 KAWASAKI MULE (A51243)
2023 KAWASAKI MULE...
2014 John Deere 544K 2 Wheel Loader (A47384)
2014 John Deere...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
