Ford 1210 Front Differential 4WD Ring & Pinion Gear
   / Ford 1210 Front Differential 4WD Ring & Pinion Gear #1
leoamaya
Ford 1700
I have bad teeth on both the ring and pinion gear on the front differential on my Ford 1210 tractor. SBA322050420 is no longer stocked by New Holland and I cannot find a used set. Q: Is the same Gear & Pinion gear set (SBA322050420) used on the Ford 1110 tractor?
   / Ford 1210 Front Differential 4WD Ring & Pinion Gear #2
Welcome to TBN! Yes, the 1110 and 1210 use the same ring and pinion.
   / Ford 1210 Front Differential 4WD Ring & Pinion Gear #4
Parts guy should know that.
   / Ford 1210 Front Differential 4WD Ring & Pinion Gear #5
So weird I have a ford 1210 with front axle reverse pinion ring gear. Trying to find a replacement. Anyone heard of a reverse pinion gear on these tractors?
Thx
JLG MAN LIFT (A52472)
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
