Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #291
I disagree just cause you can afford to own a dually 1 ton and a 30' gooseneck doesn't mean you should drive it. However imo they really need to clarify laws better, make certain exemptions easier to get and understand, and as you mentioned earlier truck and trailer makers need much better clarity on what your truck and trailer can haul.
I agree to a point but as has been said before, Going to the trouble/Time/Expense (~4k) to get a CDL just to drive a Pickup and Gooseneck over 26K is ridiculous. There needs to be some less costly and reasonable classification for them.
  • Good Post
Reactions: LD1
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #292
I sure missed it somehow. I had been checking max weights a while and thought I was still seeing the same 18K for F350 SRW CC 4x4 Diesel. Our Toyhauler is the heaviest Bumper pull at 15K. I can't imagine 18K on the receiver, let alone 20K!
Ours is a 2019 so it's max is 18K conv. but the receiver hitch shows 21K. (20.4K gooseneck)
I’m sure I’ll get a 2024 with the 6.7 HO and it will have a 25k bumper pull rating. I’ll never pull that much but it’s sure nice to use things well under their rated capacity. Instead of getting and aluminum 14k trailer to haul my 11600lb excavator I’d like to get an 18k to pull it. Still be under the ignorant 26k mark weight wise but de-rating puts you over the trailers rating. Just dumb.
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #293
And that’s fine to disagree, but there should be no government interference in what an individual feels they can do. It’s up to them to be safe. And if something happens it’s between them and the others involved. We get sooo wrapped up in putting out legislation to fix this and that, annd it eventually constrains the living p@@@ out of us without making a difference except to make the legislation machine much bigger. It’s like feeding a monster, eventually it will be too big and eat you up.
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #294
I understand your point and other folks with similar pov.
I feel what some folks say or think they can safely do and what they actually do or what happens are usually different in my experiences.
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #295
Me personally, I think everyone is crazy. But it’s none of my business what they do unless it affects me. Then we have a problem. I don’t make up problems that “might” need fixed. If they hurt or kill someone it’s their responsibility. But laws rarely change that cause those people are going to do it regardless of laws. Just like guns. Laws only affect the ones who follow them, not the ones that don’t and commit the crimes.
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #296
Lots of people can afford to buy a compact car or sedan and shouldn't be driving them either :ROFLMAO:
But the point was.....from the bottom end of the scale....a 1/2 ton pickup and little single axle trailer.....up to a dually and gooseneck, there really is little difference. Certainly not a difference enough to warrant 4-6 weeks of training and $4000 to hold a license equivalent to what someone operating a tractor trailer needs to have, along with the continued medical exams, logs, and stricter rules/penalties even while operating a personal car. You are under stricter rules and punishments for the sole reason of having a CDL.
Someone with a 2005 chevy dually (11.2k gvw) and 14k trailer is 100% legal all day long with no CDL to tow a skid loader or mini-ex all day long. But the same guy with the same trailer and equipment but has a 2005 dodge dually (12.2kgvwr) now all the sudden needs has to go through the hoops of getting a CDL-A? Tell me in what world that makes sense? OR a guy wanting a 16k trailer but debating between a 3/4ton truck or a SRW 1-ton. One combo requires a CDL, the other doesn't.
And now, a modern DRW 1-ton is a 14k GVWR.....so that rules out 14k trailers. So someone wanting to tow a 10k skid loader is dropping to 12k trailer. By which most manufactures is the EXACT SAME trailer....simply with lighter axles. So again, in what world does this make sense?
There are thousands of contractors all over this country running dually trucks and 14k equipment trailers for their business. Either pulling trenchers, or skidloaders, or mini-ex's.....small landscape type companies. But within the last two decades and truck manufactures pushing the GVWR's of their trucks beyond 12k.....or the trailer manufactures pushing the ratings of trailers to 15k for a pair of 7k axles (or even if a contractor wants to upgrade to 8k axles to get the better 17.5 wheel/tire combo).....now all of the sudden they are supposed to spend 4-6 weeks and $4000 to get a CDL-A???
Fortunatally, in most states they turn a blind eye. Because the laws on the books are unrealistic.
To be clear, I am not talking about the hotshot guys that make a living driving. Those running interstate with 3-car wedges, or 40' trailers. Im talking about the small business that rarely go beyond 30 miles from home and just trying to work the small equipment they have. They aren't making a living driving.....driving is just a necessity of getting to/from their jobs. I happen to be one of those type....just a one man show with a pickup, mini-ex, and tractor and want to use it to make a buck. Fortunately, I dont live in a nanny state.
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #297
For using a tandem axle equipment trailer folks should be familiar loading and balancing it correctly not to mention securing 5 or more tons of load.
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #298
Much excellence in post quality. Around the jobsites we do are usually new houses in new subdivisions, and as they get filled sometimes we get to know the homeowners. Cops seem to congregate together. We had a few state dot’s move in and got to know them. They said they never pull us over for checks cause we were the “working men”, but would have to under serious circumstances, understandably.(could be BS) But the laws are displaced and dated. They are just laws thought up by legislators. There is no reason, as a plumber, i should have to buy an aluminum trailer when a cheaper steel one rated to higher capacity would work just fine just to match gvwr stickers so i can pull equipment.
The ironic thing is that i am also farm exempt and can haul 38k worth of hay and equipment, or cattle within 150 miles just fine. I’m capable there, but not here…its just stupid.
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #299
The best tool i have bought for hauling is a tongue scale. No guessing.
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #300
If we are going to bother with licenses (brief rant on the fact that parallel parking is required on the test, but merging on the highway is not), I would go with something like this:
Class C: 2 axle vehicles under x size and weight no towing of any kind allowed.
Class B: Class C with bigger vehicles allowed and trailers with up to 2 axles.
Class A: If it can be driven, you can drive it.
If it were up to me, driving would be something you get certified in if you want, but if you do it wrong and hurt someone else, you pay huge. Licenses are just about money.
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A53472)
2018 Rock Solid...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A51246)
2016 CATERPILLAR...
(APPROX 80) 2" X 3" X 19 3/8" ANGLE IRON (A51247)
(APPROX 80) 2" X...
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53472)
Texas Post Driver...
