"Chrome hydraulic cylinder rods?
   / "Chrome hydraulic cylinder rods? #21
But I'm wondering why a nitrided rod would have more tendency to break? Its as if the nitriding process creates microscopic stress risers in the rod surface. I am still, however, wondering about hydrogen embrittlement of the rod surface which is what some plating operations produce.
I would suspect it's more about the nitriding process affecting the heat treat of the base material since it occurs at elevated temperature.
I'm surprised nobody is doing PVD coatings on hydraulic cylinders. Rods coating with TiAlN via PVD would be superior to bright electroplated chrome in basically every physical category...
   / "Chrome hydraulic cylinder rods? #22
………..I'm surprised nobody is doing PVD coatings on hydraulic cylinders. Rods coating with TiAlN via PVD would be superior to bright electroplated chrome in basically every physical category...
Maybe it’s an issue with adhesion if the rod flexes under extreme use?
Even chrome chipping off can be a real problem but I’ve only seen it on hyd rods with super heavy chrome.
   / "Chrome hydraulic cylinder rods? #23
I really don't know for sure but I doubt it's that. PVar coatings are only about 5um thick and there's a a molecule scale bond so they don't really chip like thicker electroplated coatings would. Also the primary usage is for machine cutting tools and those have way more flex than people would expect.
I did have a second thought that DLC maybe would be an even better option....
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53472)
UNVERFERTH 330 -...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2023 LMC H40024 LOT NUMBER 190 (A53084)
2023 LMC H40024...
