pressure gauge to check hydraulic pressure on Kioti CK2510
   / pressure gauge to check hydraulic pressure on Kioti CK2510 #1
SCWOOD
Easley S.C.
Kubota BX1800 Kioti CK2510H
Where to get a gauge? Do you buy the gauge and the fittings? I want to connect to the loader disconnect. Where to get the male fitting? Thanks!
   / pressure gauge to check hydraulic pressure on Kioti CK2510 #2
Might look here.... Go to this pager and scroll down some.... And yes it's ok to disconnect one of you FEL hoses and place gauge in place of hose and dead head the gauge long enough to get reading..... How you adjust relief pressure should be in your tractors shop manual....
I just had a thought, I can take the male fitting off the loader hose and put it on the gauge. What size thread is the fitting? Is it NPT or BSP?
   / pressure gauge to check hydraulic pressure on Kioti CK2510 #4
I can't see it from here. Take it off and measure it. ;)
Forgot to add: Make sure you get a gauge with the expected pressure in the middle of the range of the gauge. If you expect 2000psi, get a 4000psi gauge. It will be more accurate as well as safer.
   / pressure gauge to check hydraulic pressure on Kioti CK2510 #5
This is great. They have charts and PDFs to match up your Quick Connector. I asked my dealer to check all my pressures while he was fixing the BH joysticks and rebuilding an FEL cylinder but I don't believe he did.
LANDHONOR BS-12-2500G (2) PRONG HAYSPEAR (A57193)
LANDHONOR...
UNUSED JCT HYD VIBRATORY PLATE COMPACTOR (A57193)
UNUSED JCT HYD...
2000 Chevrolet C2500 Ext. Cab Pickup Truck (A55852)
2000 Chevrolet...
UNUSED IRGC40 MINI ELECTRIC GOLFCART (A57193)
UNUSED IRGC40 MINI...
2012 Freightliner M2 106 Medium Duty Altec LRV36 56ft Forestry Chipper Bucket Truck (A55852)
2012 Freightliner...
UNUSED JCT 2 PRONG BALE SPEAR (A57193)
UNUSED JCT 2 PRONG...
