New Holland Tn75f engine trouble
   / New Holland Tn75f engine trouble #1
simonpd
New Holland tn 75 f
Bought a second hand Tn75f with engine troubles. 6000h - 1998.
I try to figure out where it has gone wrong.
So far i checked all minor things.
Fuel ok - pump ok - injectors tested and ok.
It was cranking ( very slow) but not firing up.
I ve tried this with the injectors removed and noticed 2 cylinders where not blowing any air out, nothing!
I m not a mechanic and so far my knowledge...
It seems 2 Pistons in the Middle are not moving.
What could cause this? Blown piston?
Piston 1 and 4 are moving and blowing air out, 2 and 3 just don't.
Anyone a suggestion what i can try myself ? I m out of options myself.
   / New Holland Tn75f engine trouble #2
I'm not a mechanic
Take it to one (or find someone to come out, that is). You could take the valve cover off for a look see first. Could be valves stuck, rockers broke, pistons/rings bad... Lots of expensive things, are possible. Hope you didn't pay much for it.
   / New Holland Tn75f engine trouble #3
pull the valve cover off to check the valve train, if thats good;
pull the oil pan if possible or the head.
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2015 CASE 580N (A47477)
2015 CASE 580N...
2020 CHEVROLET SILVERADO TRUCK (A51406)
2020 CHEVROLET...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
