Good morning!!!!
   / Good morning!!!! #165,811
That's a real work of art, KJC. But aren't you supposed to use bailing wire and chewing gum together?🤣
Seriously, though, if that turns out to be the cure, a few minutes up on a rack at your local muffler shop will get a few tack welds in there to permanently cure the buzz.
Update: it is working GREAT!!! Mrs is very happy that it doesn’t sound like a hoopdie with fart-can mufflers anymore 🤣😂
   / Good morning!!!! #165,812
I bet that'll rattle like crazy, in no time.
It has been rattling like crazy, and now it doesn’t.
I have three spools of wire - I can do this almost indefinitely 🤣🤪🤣
   / Good morning!!!! #165,813
Update to the updated Good Morning Update:
THE CAP IS OFF!
What a PITA. Rigged up to the rafters, applied tension, tried tapping, NOTHING.
Applied more tension, tried turning, wouldn’t budge.
Applied more tension, applied pipe wrench, it started turning, and s l o w l y began to move upward…
We also got one strand of barbed wire up the whole length of the fence, maybe will do another one tomorrow. . .
thank you for all the advice on the cap - I hope my end of it was at least entertaining! 😁👍
   / Good morning!!!! #165,816
Kilroy, glad you got it figured out. Looks all rusted up.
RNG, the options you give up can be added via aftermarket I am sure.
When I ordered the Sprinter they screwed up and did not give me the suspension seat option. All the other options came through.
Are you mainly going to use it as a cargo van or are you converting to camper?
The high roof option on ours allow standing up without bumping the head.
The power of the engine looks good. Mine is only about 170 HP but it is plenty peppy I think. Yours with 275 and 10 speed transmission should be fine
   / Good morning!!!! #165,817
Good (Sunday) morning. The overnight Low was a balmy 18C and it's presently 19.5C, very overcast with the odd gust. The Bureau Of Many-guesses actually got it right last night, in that thunderstorms did (and are) sweep through with heavy downpours. It's still raining and I haven't been out to check my gauge.
I'm off to Church in about an hour from now, then the rest of the day is 'His'.
Gauge update: 34.2mm @ 0830.
   / Good morning!!!! #165,818
There is nothing like baling wire for fixing exhaust systems.
Got all my plowing done, my banks shoved right back to the bush in preparation for the next snowfall. Did the other 5 driveways I look after. Now for the you tube rabbit hole.
   / Good morning!!!! #165,819
50F and sunny @ 16:00, which was/is probably the high for the day. Two day rainfall total was 2.42". Heading down to around 38F tonight for the low.
Up very late last night (04:00), working out in the garage.
Got another piece of Wonderboard Lite trimmed, drilled, and fitted for the main bathroom yesterday. Also cut some pieces of wood for supports to screw into, will probably get those put up today. Might even get the Wonderboard up as well.
Woman just announced that we had an Amazon delivery ... and then threw the packages at me ...
:LOL:
Looks like a new set of calipers (yay !), two assortments of nutserts (metric and imperial), and a digital angle finder box.
She subsequently announced that if I heard her go outside it was because She want to take a walk and get outside on this (reasonably) nice day ... (y)
Also got end trimmed on bottom of blast gate manifold with Japanese pull saw, foam installed, plastic tube glued, and mounting rail attached:
And mounted on the wall and most of the hoses run:
Short one fitting to connect the belt/disc sander which is due in tomorrow from Amazon. Still need to connect up and attach the hose that runs on the swing arm/Sky Hook™ as well.
Drill press doesn't have a dedicated connection to the dust collection system, but hose from the Sky Hook™ easily reaches it, if there's going to be a considerable amount of drilling taking place.
Initial testing with the Delta chop saw indicates the system has good suction (hoses compress) and it seems to do a fairly decent job of reducing the dust the chop saw throws.
I did have to wrap some electrical tape around a pair of 2 1/2 ---> 1 1/2 reducers to get a snug fit inside the 2 1/2 hose. In fact, I still have some to do on one of them.
Probably run over to Lowes or Home Depot here in a bit and pick up some 3" plastic J hook pipe hangers (which I did not have in stock) to clean things up a bit.
Shop Vac is starting to get heavy-ish so I'd like to dump its contents out on the floor and then suck it all back up, running it through the dust cyclone/separator to see how well it works.
Anyways that my story for now.
Hope everyone is having a good Saturday ... (y)
   / Good morning!!!! #165,820
Gas tanker wrecked, reports say he got cut off. He passed away.
One house burned also, and a couple other vehicles.
Wild day, had a vehicle go in the river at a boat ramp, police shot an armed man, couple other fires.
40' High Cube Multi-Door Container (A57149)
40' High Cube...
2014 Chevrolet Tahoe SUV (A56859)
2014 Chevrolet...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED FUTURE NWS38 38" WOOD SPLITTER (A58376)
UNUSED FUTURE...
2008 BMW 535xi AWD Sedan (A56859)
2008 BMW 535xi AWD...
