5045E Wiring/Diagnostic Guide
   / 5045E Wiring/Diagnostic Guide #1
I have a 2013 5045E that won't crank. I am trying to diagnose the problem. I have TM901619 29April15. I don't think it is right for my tractor. Can anyone help?
   / 5045E Wiring/Diagnostic Guide #2
I would start basic troubleshooting with a good multimeter. Battery voltage? Now try cranking...voltage? If it drops a lot, replace battery, if no change check fuses & connections.
   / 5045E Wiring/Diagnostic Guide #3
Welcome to this forum.
Have you cleaned/tightened ALL FOUR(4) battery cable connections? What is battery voltage before & during attempted start of engine? Have you checked for a blown fuse?
Yes. I have done all the simple basic things. I need an actual wiring diagram. Could be a bad key switch, relay, wire, ect...
   / 5045E Wiring/Diagnostic Guide #5
How many volts did battery show when you tested it? With """trans in neutral""" have you attempted to short across large terminal & "S" terminal on starter solenoid to determine if starter gear will engage flywheel ring gear?
Plenty of voltage on load tested battery. The starter will not engage by doing that. I also am not getting any voltage to the "S" terminal.
   / 5045E Wiring/Diagnostic Guide #7
If starter won't engage by shorting across "S" terminal & top post on starter solenoid you have a poor battery connection, faulty battery cable or faulty starter/solenoid.
I agree the starter is probably bad. Not getting power to the solenoid is another issue.
I checked my starter relay. It is getting voltage to it, but not out of it.
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2007 CHEVROLET KODIAK C6500 (INOPERABLE) (A55745)
2007 CHEVROLET...
AIR COMPRESSOR (A55745)
AIR COMPRESSOR...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
