TD95D Hydraulic Return Question & Load Shaft Seals
   / TD95D Hydraulic Return Question & Load Shaft Seals #1
LHF2019
NWPA
IH1586, JD2350, JD2355, JD2950, JD4040, JD4430, TD95D
Purchased a post pounder(old, old, old Shaver) and without purchasing a new valve for use on our closed center JD I am going to use on the NH for time being. Is the dipstick/fill hole the easiest or only place for the return line?
For the load shaft seals, can the assembly just be unbolted and dropped from the tractor to make removal easier? On JD there is room to work. NH planetaries are in the way. Repair manual is of no help.
Thank you for the assistance.
   / TD95D Hydraulic Return Question & Load Shaft Seals #2
I don't have my service manual available but I think the fill hole with the dipstick is the only one I am aware of. It is rather small for a return line. Look around on the top of the rear axle area to see if there is one there. Otherwise talk to the service people at your local NH dealer. You might also look at the parts catalog at Messicks.
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
(INOP) 2019 CATERPILLAR 336 EXCAVATOR (A51246)
(INOP) 2019...
Vermeer D16X20A Directional Drill with Mixing System and Trailer (A51573)
Vermeer D16X20A...
UNUSED X-STAR 101" X 25' BRIDGE PLATFORM (A51247)
UNUSED X-STAR 101"...
