John Deere 1050 4WD - Lost Left Rear Wheel Drive
   / John Deere 1050 4WD - Lost Left Rear Wheel Drive #1
Rickanson
John Deere 1050
In an effort to free up a frozen brake on the left rear wheel over the winter, I apparently lost the drive on the left rear. The right rear only drives when the differential lock peddle is enguaged.
I have started to disassemble to gain access to the axle housing but have not removed it yet. I did removed the ledt brake cover and found a little.watrer and corrosion on the spring and hardware. The shoes appeared new and the drum surface was smooth.
Before for f go further I wanted to search out some guidance from members who have performed this type of repair.
Thank you in advance for any help that you offer.
   / John Deere 1050 4WD - Lost Left Rear Wheel Drive #2
This is an often enough occurrence at times for these Yanmar made Deeres. A few YT vids are out there.
Should you need manuals for free, come check us out.
And the Yanmar/Deere/Cub Cadet brake axle repairs.
   / John Deere 1050 4WD - Lost Left Rear Wheel Drive #3
You probably sheared the brake pinion shaft. I've done this on a JD2030 & a YM1610
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
Landoll Lowboy Trailer (A55218)
Landoll Lowboy...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A54607)
2017 INTERNATIONAL...
UNUSED LANDHONOR PHA-16-2C HYD 3PT HITCH MOUNT (A54757)
UNUSED LANDHONOR...
