Diagnosing cause of deadhead hydraulics pump
   / Diagnosing cause of deadhead hydraulics pump #1
Peteycrete
Yanmar 4220D
My pump blew the housing. Before I put another one on I feel I should figure out where the clog is that caused the pressure that blew it. What is the best practice to trac down where the clog is?
I have a Yanmar 4220D btw
   / Diagnosing cause of deadhead hydraulics pump #3
Hi,
I'm not sure of the set up on a Yanmar, but Ford 3000 and Massey 35 have pressure relief valves. Yanmar likely use one too. I would suggest if the hydraulic pump pressurised any part of the system to failure, then the relief valve may have failed. Not suggesting that a failed relief valve caused the high pressure that did the damage, just that if damage was caused by high pressure, then the relief valve didn't do it's job.
   / Diagnosing cause of deadhead hydraulics pump #4
If you expect much meaningful help, it might be wise to post some photos of your system, maybe explain some of the details concerning what the tractor has (hydraulic wise) other than a three point lift. Any history of work recently done, anything changed in regards to hydraulic before this happened.
Otherwise, you're going to get a lot of replies, mostly guesses, from people who know less about your tractor than you do. Much of what you get probably won't apply to your situation.
   / Diagnosing cause of deadhead hydraulics pump #5
The best after you repair/replace the pump is to put a direct acting relief valve tee’d into the pressure line coming directly out of the pump and run the discharge hose from relief valve to an empty clean 5 gal bucket. Preset the relief valve using another hydraulic source about 100 psi over your tractor max psi specs. While you are doing your scouting adventure to troubleshoot your current issue downstream you won’t have to worry about ruining another pump, the excess oil will dump into the clean bucket with no harm and you can filter the oil and reuse it.
If you don’t do this you run the chance of blowing up another pump
   / Diagnosing cause of deadhead hydraulics pump #6
Why would you go through the trouble and expense of all that? The system most likely has a relief valve somewhere now. Cutting into hard lines, adding in a bunch of new parts and plumbing makes no sense. The common sense approach would be to look the system over, figure out what went wrong, then repair/replace the pump. Precautions can be taken to reduce chances of a repeat failure without all that.
You have no idea how the hydraulics on this tractor are currently set up, or why the pump did what it did. Why would you expect someone to put all that together before concluding it was necessary?
   / Diagnosing cause of deadhead hydraulics pump #7
Yep. That's exactly what I would do. How to do it needs some details to flesh it out for hydraulically challenged, but if you can replace the pump you can definitely add a relief valve. Once you do that, you can trouble shoot the rest of the system at your leisure because you know that the new pump is protected. Plus you can ask to get any needed advice right here. This works so easily because almost all of these basic open center hydraulic systems on compact/utility tractors are the same (except some JDs). The pressure pump is brand specific only because of the mounting configuration, but the insides of the pump are similar. And after the pump the rest of the system tend to be so similar that they can use interchangeable parts.
For that matter, a person can simply plumb in a PTO-driven hydraulic high pressure pump on any tractor. Those used to be popular back when tractors didn't come with pumps mounted on the engine. Some attachments use them today instead of using rear remote hydraulic outlets driven by an engine mounted pump.
There is no downside to adding another relief valve. It's like having a belt and suspenders. You can buy a relief valve online from several sources for under $100. Surplus Center.com, Summit Hydrauics, or Zoro. I would get one with the proper threads or adapters so that it can simply be threaded on inline in series between the pump high pressure outlet and where ever that line goes first. No cutting involved. Go overboard for another thirty bucks and add a 5000 psi glycerin-filled pressure gauge while you are at it. More fun than a TV. The relief valve itself should be pre-set for whatever pressure you decide you want to limit your system to..... or you can do it just as wdchyd said in post #6 above. Setting a relief valve takes less than ten minutes with one wrench and one screwdriver. I tend to run less pressure instead of more, so I set mine at 2500 psi on my YM336D. The relief valve will also need a return line capable of handling the flow. You can run that low pressure return ine down to a "Y" into the existing return line.
Do you have a loader on it? If so, post some photos of the control assembly and we can get more specific.
BTW, every loader control valve I've ever used has a relief valve built into is so that most plumbing errors won't break the high pressure pump. Weird that yours did that. There is also a relief valve in the 3 pt system. The most common error that will break the pump is trying to add a loader to a system
without understanding the hydraulics in the loader control valve and using the wrong power beyond adapter plug. That error will blow a high pressure pump up sometimes. But putting an additional relief valve as described above so that it is between the pump oulet and the input to the control valve will protect even from that error.
Good luck with it,
rScotty
   / Diagnosing cause of deadhead hydraulics pump #8
I think that he is saying the same I am. The open center hydraulic on a compact tractor is a very simple system not at all brand specific. Like front drive axles or battery/alternators It is much the same for all the tractors made (except JD). If a person understands one open center system they understand them all.
Adding additional relief valves doesn't change a thing except to reduce the chance of breaking another pump while troubleshooting. However, many of the tractor manufacturers made the same mistake of not putting a relief valve port in the position we've discussed. Some did, some didn't. On the ones who didn't, their oversight allows a common hydraulic plumbing error - often made while adding a FEL - to end up ruining a pump or worse.
These solutions posted simply correct that common manufacturing mistake and allow safer troubleshooting. No different in my mind than wearing protective glasses when hooking up a battery.
rScotty
   / Diagnosing cause of deadhead hydraulics pump #9
Yes rScotty, the external relief valve would only be temporary enough to find the real problem.
Generic direct acting relief valve and a few fittings are a great alternative to having another pump blow up.
And it doesn’t have to be tee’d in directly at the pump outlet, but needs to be before any other component (ie: flow divider or FEL valve)
If bad things happen once they can and will happen again going in blindly to find the issue.
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A52377)
2008 24ft...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55301)
2000 Kenworth W900...
2021 CAN-AM OUTLANDER 650 XMR 4-WHEELER (A51406)
2021 CAN-AM...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
John Dozer JD650 (A51691)
John Dozer JD650...
John Deere 853 20ft Corn Head (A55301)
John Deere 853...
