Canned Spray Foam/ Brake Clean
   / Canned Spray Foam/ Brake Clean #2
Cool! Learned another trick!
   / Canned Spray Foam/ Brake Clean #3
Great tip! Always hated to "waste" a whole can when all you needed was a small project.
So do you spray the brake cleaner thru the nozzle to clear it? What about the part of the can the nozzle threads onto?
   / Canned Spray Foam/ Brake Clean #4
Brake cleaner (chloronated or non) is the best wasp, hornet and yellow jacket killer ever made. I use it all the time to eliminate those pests. Wipes out a nest instantly.
   / Canned Spray Foam/ Brake Clean #5
Great to know ..
Most brake clean has some amount of acetone in it.. which is the main dissolving agent for spray foam cleaner.
You can also purchase pressurized cans of acetone just for cleaning up after spray foam.
   / Canned Spray Foam/ Brake Clean #6
Here is a neat trick, take the paper off of an old filtered cigarette butt and place it in the palm of someone else's hand. Add about a tablespoon of acetone quickly for a gross surprise.
I sprayed down into it to clean it too.
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2017 Chevrolet...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2017 Ford Expedition 4x4 EL XLT SUV (A51694)
2017 Ford...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53473)
2024 BCL...
2025 K1220 UNUSED Single Garage Metal Shed (A53117)
2025 K1220 UNUSED...
