D170 - extending K46 transmission life?
   / D170 - extending K46 transmission life? #31
I know this is an older thread. I wanted to share my solution for modifying the K46 so you can change the oil without having to take the transaxle off your mower: https://youtube.com/playlist?list=PLd1vGGfDybyGtF_MG0fJscUE2pO8VWHN0
Basically: drilling drain plugs and converting the vent hole to an external expansion tank. Filling is accomplished by pumping oil in through a drain plug hole until it starts showing up in the expansion tank. Then temporarily block the vent cap on the tank to create a fluid lock so you can unscrew the pump and put the drain plug back in without all the oil draining out. The pump I use is a cheap lower unit pump that is typically used on outboard motors.
   / D170 - extending K46 transmission life? #32
That was a lot of work in doing that but it was done well. It takes me about 3 hours to pull my tranny, drain it, fill it and install it. I do that about every 200 hours or so, which amounts to every other Fall.
   / D170 - extending K46 transmission life? #33
Interesting video, and a nice job done. I only watched the 2nd video as I not concerned about a tuff torque transmission at this time.
I did have to pull, flush and refill one in a JD lawn tractor as It wasn't pulling real good. Drained flushed and refilled with 20W-50 synthectic and still use it a couple of times a year for trimming or rough areas were I don't want to put my F2000 or it wont fit.
   / D170 - extending K46 transmission life? #34
Thanks! Yeah it was a lot of work. I like doing one time stuff like that. The thought of pulling the trans off as part of regular maintenance pains me. My trans failed at 130-140 hours. So I want to try changing the oil every year when I change the engine oil. I’m hoping that combined with using synthetic oil will keep the trans alive this time.
2006 Nissan Titan Crew Cab Pickup Truck (A53422)
2006 Nissan Titan...
ITEM LOCATION (A53084)
2018 CHEVROLET SILVERADO 2500HD (A55745)
2018 CHEVROLET...
2013 FORD F-350(INOPERABLE) (A55745)
2013 FORD...
207010 (A55853)
207010 (A55853)
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
