Kubota L3540 Fluid change??
   / Kubota L3540 Fluid change??
I have a small hand pump I used to fill mine on the 400 hr fluid change. It took a while as it does not pull much per stroke like you found, but the time actually goes pretty fast and I didn't have to balance those heavy 2.5gal containers over a funnel in the air...
Glad you got 'er dun
Yeah, I had to balance a 5 gallon bucket over the funnel!
And thanks.
   / Kubota L3540 Fluid change?? #12
5 gal pail pump works great for volume
The 5 gal bucket pump I looked at delivered 3 oz per pump, for 10 gallons that's 1280 pumps, I don't think so!
works great for my 15 gal hyd change. sure beats a small transfer pump or suction gun that really gets messy. i'm not afraid of repeated handwork as long as it limits contaminants & reduces the mess...
good luck on the change, regards
Yep, that's the exact one I was looking at, 3 oz a pump, no thanks.
I muscled those 5's up there and was done pouring in 10 minutes.
   / Kubota L3540 Fluid change?? #16
here's another op for you, maybe out of your price range. saved me a lot of labor refueling. but it would work for hyd oil as well. will make quik work out of a 5 gal container, faster than my mr funnel can accomodate (@ full throttle) flow can be regulated @ nozzle trigger. best regards
   / Kubota L3540 Fluid change?? #18
probably so, yours sounds like a small task. lots of gadgets out there, good luck on the change, regards
   / Kubota L3540 Fluid change?? #19
Late to the thread but Did you pull ALL the drain plugs? The kubotas I have had there are multiple for the hydraulic/trans fluid. There are the big ones under trans and/or rear end.....but you also have to pull two out of either axle.
In either case.....sometimes I over fill a bit.....if I raise the loader and dump the bucket (makes the loader consume the most fluid) and get back to within a good range then I know its not "that" overfilled and I leave it alone.
If yours is a HST and you use the appropriate kubota SUDT.....chalk it up to a lesson learned at nearly $30/gal for the oil
I just bought the two hydraulic filters, 2-buckets of SUDT, and an engine filter from the kubota dealer. (I use rotella T6 for the engine sourced elsewhere). That was ~$480. So with the rotella I'll have about $520 in this next service
LOT#165 ELEC MOTOR APPOX 25HP (A59213)
LOT#165 ELEC MOTOR...
40' High Cube Multi-Door Container (A57149)
40' High Cube...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
2016 CATERPILLAR 262D SKID STEER (A52709)
2016 CATERPILLAR...
UNUSED CFG INDUSTRIAL H12R EXCAVATOR (A58375)
UNUSED CFG...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58216)
RAKE ATTACHMENT...
