Can anyone succinctly explain trailering numbers found in a Ford Vin lookup?
   / Can anyone succinctly explain trailering numbers found in a Ford Vin lookup? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
For instance on a 2023 F150, 5.0L V8 Engine a VIN lookup shows:
Wt Distributing Hitch - Max Trailer Wt. 10500, 9500, 8100 lbs 7600.0 min 13800.0 max
I'm ASSUMing that means it has a 13,800 max tow capacity but y'all know what they say about ASSUMe.
But what are all the other numbers?
Trying to work with a dealer they want a ton of details before they'll talk to me.
Why doesn't the dealer know what it means?
Bruce
Thanks for the link.
The last three dealers I tried to deal with always had to "consult" someone with more knowledge and didn't get back to me.
I've found that I usually have to go in to the dealership, which I don't want to do until I've found something they have on the lot.
/edit
And I've read that with the new beer can bodies they are "tuned" to a maximum tow weight far closer than those of the past.
   / Can anyone succinctly explain trailering numbers found in a Ford Vin lookup? #6
You have the actual VIN for the truck or you are just trying to figure out what one could tow?
Looks like anywhere from 8300 to 13000 on the Ford tow chart
   / Can anyone succinctly explain trailering numbers found in a Ford Vin lookup? #7
I am frustrated with towing specs also.
They show combos they will not let you order - maybe that's it.
I want a 5.0 3.73 - not allowed, but rated.
   / Can anyone succinctly explain trailering numbers found in a Ford Vin lookup? #8
   / Can anyone succinctly explain trailering numbers found in a Ford Vin lookup? #9
I wonder if those may be for export only as they might lower average fuel economy in the US.
Bruce
   / Can anyone succinctly explain trailering numbers found in a Ford Vin lookup? #10
You might have gotten a lot more responses if you didn't add the qualifier "succinctly". ;)
2016 Toro Workman HDX-D Diesel Utility Cart (A59228)
2016 Toro Workman...
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A60460)
2020 Ford F-250...
2016 Chevrolet Malibu Sedan (A59231)
2016 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
DEUTZ MARATHON...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
