Can anyone succinctly explain trailering numbers found in a Ford Vin lookup?
   / Can anyone succinctly explain trailering numbers found in a Ford Vin lookup? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
For instance on a 2023 F150, 5.0L V8 Engine a VIN lookup shows:
Wt Distributing Hitch - Max Trailer Wt. 10500, 9500, 8100 lbs 7600.0 min 13800.0 max
I'm ASSUMing that means it has a 13,800 max tow capacity but y'all know what they say about ASSUMe.
But what are all the other numbers?
Trying to work with a dealer they want a ton of details before they'll talk to me.
Why doesn't the dealer know what it means?
Bruce
Thanks for the link.
The last three dealers I tried to deal with always had to "consult" someone with more knowledge and didn't get back to me.
I've found that I usually have to go in to the dealership, which I don't want to do until I've found something they have on the lot.
/edit
And I've read that with the new beer can bodies they are "tuned" to a maximum tow weight far closer than those of the past.
   / Can anyone succinctly explain trailering numbers found in a Ford Vin lookup? #6
You have the actual VIN for the truck or you are just trying to figure out what one could tow?
Looks like anywhere from 8300 to 13000 on the Ford tow chart
   / Can anyone succinctly explain trailering numbers found in a Ford Vin lookup? #7
I am frustrated with towing specs also.
They show combos they will not let you order - maybe that's it.
I want a 5.0 3.73 - not allowed, but rated.
   / Can anyone succinctly explain trailering numbers found in a Ford Vin lookup? #8
   / Can anyone succinctly explain trailering numbers found in a Ford Vin lookup? #9
I wonder if those may be for export only as they might lower average fuel economy in the US.
Bruce
   / Can anyone succinctly explain trailering numbers found in a Ford Vin lookup? #10
You might have gotten a lot more responses if you didn't add the qualifier "succinctly". ;)
CHAMPION AIR COMPRESSOR (A55745)
CHAMPION AIR...
1999 INTERNATIONAL 4700 24FT BOX TRUCK (A56138)
1999 INTERNATIONAL...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
PNEUMATIC JACK (A55745)
PNEUMATIC JACK...
2011 KENWORTH T800 (A55745)
2011 KENWORTH T800...
