kleinhhl
Member
I recently had to split my John Deere 1050 into three pieces to replace two seals in the clutch input shafts. What a job!
When I went to the John Deere dealership to buy new hydraulic fluid, I was about to pick up regular Hy-Gard but the man behind the counter said, "Wait! You need to use Low Viscosity in the 950 & 1050s!" So that's what I bought --- 6 gallons cost $165!
I did do a cursory look online and found a JD document that stated both were acceptable in these tractors.
However, I have since found the temperature graph below and it's got me worried that I should have gone with regular Hy-Gard due to the max air operating temperature of Low Viscosity being only 86F --- which in Virginia it gets much hotter.
After putting everything back together, the tractor runs & operates as normal but I now have a slight grinding when putting her into gear if I don't wait an extra second or two for the gears to stop spinning. Never had that problem when I ran straight Hy-Gard.
My experience is similar to this post: John Deere 950 light grinding into gear
I know the clutch is adjusted properly because I checked when she was apart with a feeler gauge and special tool JDG-52 (yes, I bought it for $99!!!
). By the way, I'll beposting the measurements of that special tool in case someone wants to re-create it for their own use.
I do need to check the adjustment of the clutch petal but I think it's also okay.
I'm thinking that the lower viscosity is letting the gears spin freer hence the extra time to wait for them to stop spinning before I can shift.
Overall, it's not much of a problem just different from before. Should I run the Low Viscosity Hy-Gard or switch out to regular Hy-Gard?
Love the JD1050, she's a beast. It has a Woods loader and I run a grapple, 3ph round bale spear and Woods grader.
