Flail Mower frail mower vrs rear finnishing mower
   / frail mower vrs rear finnishing mower #21
My flail mower experience is different then a lot of people: I do Not find it the perfect combination of a bushhog and finish mower. I find they cut grass like a bushhog and scrub like a finish mower. Not Goldie Locks to me; it's more of a neither fish or fowl situation.
Specifically with Bahia, mine (Ford 917L with hammer flails) doesn't do a good job cutting the tall seed heads off. Now, if your cutting every time anything gets over 3 or 4"; that might not be a issue; but bahia likes to go from short; to 18" seed heads in 12 hours after a good rain.
   / frail mower vrs rear finnishing mower #22
mclogn, if this has been hit directly, I missed it. You would do good to look at the different options in flail mower blades. There are light weight ones that run in pairs on same connection point forming a "T" or a "Y" for grass, lawn type mowing. There are heavier blades similar to those. Then to the far side there are those called hammers which really will mulch most small trees (here a oak is hard on any type of mower) and heavy grass.
Looking at the type of cutters the mower has on it gives a good indicator of the duty it is made for.
One other reason I do not try to mow finish grass with my flail is the turning. Totally forgot that. My flail mowers and all I have ever looked at have a rear roller. FOR ME and maybe I was the problem, I would often damage the grass when making sharp turns that a mower on wheels would not. When I can turn a tractor tight enough to damage the grass with the mower and not the front tires, I don't think it is right mower for the job.
At same time I use my hyd offset flail mower with hammers on it to trim the road ditch in front of my house. Why, it keeps a machine away from the ditch and does a suitable job. Not a finish mower cut, but sure beats a hand held trimmer.
   / frail mower vrs rear finnishing mower #23
Hello and good morning Mr. Harvey.
The scoop/spoon flail knives on the Ford 917 are a flail knife that is a general purpose knife to allow the end user to mow brush and grass.
If the scoop/spoon knife is dull it will not slice the brush or grass well.
A sharpened spoon/scoop/side slicer knife with the proper 37 degree edge would manage your Bahia grass more effectively.
   / frail mower vrs rear finnishing mower #24
I mow my lawn with the Y grass knives and it does a fantastic job mowing a regular lawn.
Leonz has the key point... if you want a fine cut grass, you need proper sharp knives.
   / frail mower vrs rear finnishing mower #25
I mow about 6 acres with a 72 inch finish mower
for me it does a good job and the look and finish looks good .
1987 FORD 2110 TRACTOR (A51222)
1987 FORD 2110...
IH Cub Lo-Boy 154 (A50514)
IH Cub Lo-Boy 154...
Payment Terms (MUST READ) (A50774)
Payment Terms...
CATERPILLAR 304E CR EXCAVATOR (A51242)
CATERPILLAR 304E...
1984 AM GENERAL HMMWV HUMVEE (A51222)
1984 AM GENERAL...
John Deere 693 Corn Head (A50514)
John Deere 693...
