Questionable Fuel in Transfer Tank
   / Questionable Fuel in Transfer Tank
I just researched Mr, Funnel. That's an amazing piece of plastic!
   / Questionable Fuel in Transfer Tank #12
One thing I have on both my Kubota's is the Racor fuel polishing filters between the fuel tanks and the primary filter. Have not needed to change a fuel filter since. The Racor has a clear bowl on the bottom with a drain so you can drain off any contaminants. Very convenient plus you can readily see what is in the fuel and if there is any gunk. You can get the Racor with a fuel heater (optional) as well.
   / Questionable Fuel in Transfer Tank #14
   / Questionable Fuel in Transfer Tank #16
I have another question for the brain trust here. I picked up a transfer tank from the farm to use for the equipment building my driveway and pad for my upcoming house build. It has enough fuel in it that I hate to just pump it out, but there is a chance there is water in it. Is there a generally accepted way to flush/ filter the fuel in transfer tanks to ensure the quality? My brother in law said it should be good fuel in it but when he got it back from the jobsite there was no cap on the top and he knows it rained several times with no cap.
I would get rid of that crap ASAP.
Made that mistake once, and never again. Fuel injectors are VERY sensitive to contaminated fuel.
All i have left is to hope now... It looked really good going in. I checked out a few samples and it looked good. No water. I pumped it back into the transfer tank through the mr funnel for several min and looked at what was in it several times and it looked good before i ever put it in the machine.
I ran it all out today and then some. Burned 90 gallons building about 400' of driveway.
2012 John Deere 7230R (A52748)
2012 John Deere...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
2017 Massey Ferguson GC1705 Compact Tractor (RUNS) (A50774)
2017 Massey...
2004 Sterling Acterra Truck Cab & Chassis S/A (A51692)
2004 Sterling...
2005 Sterling Acterra Tender Truck (A52748)
2005 Sterling...
