Welder / Wiring for Small Garage
   / Welder / Wiring for Small Garage #71
Think so worked telecommunications for 38 years and everything from 26 gauge to 750,000 CM... And I can read the spec provided by welder manufacturer...
hold on, you are aware that #10 wire is larger and carries more current than #14 right?
   / Welder / Wiring for Small Garage #72
Think so worked telecommunications for 38 years and everything for 30 gauge to 750,000 CM... And I can read the spec provided by welder manufacturer...
i guess i'm confused about your point?
are you objecting that i gave advice that exceeded the min requirements for this specific equipment?
for the record i acknowledge that the min requirements for this equipment are as low as #14 wire for specific conditions (that i have no way of knowing for sure), i still would recommend #10 wire and a 30 amp CB.
   / Welder / Wiring for Small Garage #73
I am not objecting to anything.... Just referencing minimum requirement the welder manual states..... Which also makes reference to NEC sections...
   / Welder / Wiring for Small Garage #75
I would run awg 6. You won't regret it when you buy the next toy and find out you need a little more power. I ran #2 to my shop but it is 130' from the house and I have added numerous circuits since I originally wired it.
   / Welder / Wiring for Small Garage #76
Having more capacity sounds good, but the original post said he already had 50 amp service with #6 to the building and is just adding a circuit for the welder. If you are installing a 30 amp breaker for the welder circuit, anything larger than #10 is just wasted money and added difficulty in handling the larger wire.
   / Welder / Wiring for Small Garage #77
I agree with what you said but laughing at myself because i just talked myself into installing 3/0 for my service, it was a PITA, had to borrow a set of ratcheting cutters to cut it and forget about bending it neatly
   / Welder / Wiring for Small Garage #78
Just brainstorming ... if a future EV would be charged near the far end of this cable run, then more wire capacity now might be a good idea.
   / Welder / Wiring for Small Garage #79
After the wheel fell off of by canoe, you asked how many birds will fit in a dog house, I say well it doesn't matter because a fish doesn't have feathers.
Just trying to add a little humor!
Boy that was a long one.
Haha 😀
Well life happens wind storms that make us have to replace the roof and vacation.
Also, my around to it needs to get back in gear. 🤪
That said I’m sticking with what I outlined.
2020 CAT D6K 2XL (A55272)
2020 CAT D6K 2XL...
2025 TPM-20K W/ Yanmar Diesel Engine Mini Hydraulic Excavator W/Dozer Blade (New/Unused) (A59225)
2025 TPM-20K W/...
1990 TRAIL MASTER  TRANSPORT TRAILER (A58214)
1990 TRAIL MASTER...
2012 JACK COUNTY 130 BBL VACUUM TRAILER (A58214)
2012 JACK COUNTY...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
