Ford 1910 Timing Gear Cover Torque Specs
   / Ford 1910 Timing Gear Cover Torque Specs #1
fourbrads
Peyton, CO
Ford 1910
Greetings,
Replaced the timing gear cover gasket and started looking for the torque specs for the bolts that hold it on.
Been through all of my manuals (including the repair manual) and the closest I came was a reference to the reinstallation of the timing gear cover in the "engine" section, which said basically to refer to chapter 3 of that section for the torque specs. Checked that chapter. Nothing. Had the crankshaft pulley bolts specs and everything else, but nothing for the timing gear cover.
I know there are general bolt torque specs, but these bolts are unmarked, grade 8.
Ideas?
Thanks.
   / Ford 1910 Timing Gear Cover Torque Specs #2
Nothing in a 1310 thru 1710 manual either regarding timing cover bolt torque, all I could find is this:
Yes. The general torque specs I saw as well. Assume these were meant for metal-to-metal parts. The timing gear cover has a gasket between it and the block.
Plus, I'm not really sure what to make of the chart. The heads of the bolts are blank (except the one that goes through the alternator bracket), and being M8 (I think), that puts the torque anywhere from 9 to 26 ft-lbs, based on the chart. A pretty broad torque range.
Thank you though.
Jim
   / Ford 1910 Timing Gear Cover Torque Specs #4
For a timing cover, 9-12 should be adequate and safe
Thanks. It's a cast iron cover. Believe they are M8, grade 8 bolts. If oil comes gushing out, I'll tighten more, I guess.
-Jim
   / Ford 1910 Timing Gear Cover Torque Specs #6
-Jim
M8 identifies it as a metric bolt, not grade hardness.
I'm aware.
That's why I identified them as BOTH "M8, grade 8 bolts." Because the hardness is germane to torque specs.
Thank you, though, for reading the post.
-Jim
   / Ford 1910 Timing Gear Cover Torque Specs #8
try 1920 manual here
  • 1920 Part 1.pdf
  • 1920 Part 2.pdf
Thanks for this resource! I'll try to find it. Hopefully the 1920 is close to the 1910.
Thank you!
Jim
Well, After a through review, the bolt torque specs are not mentioned in the 1920 manual either. It describes the removal process in detail, then says the reinstall is the reverse, but jumps from "bolt the timing gear cover on" to referring to the crankshaft pulley and it's required torque.
Thanks anyway!
I think the answer to my question is: 'The timing case cover bolts are torqued to adequate ft-lbs.' I'll just go with that.
Thank you to all who offered help.
Jim
JOHN DEERE 560M LOT NUMBER 37 (A53084)
JOHN DEERE 560M...
2016 HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
2023 JOHN DEERE 8R310 LOT NUMBER 202 (A53084)
2023 JOHN DEERE...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
