Hydraulic scissor lift won't go down.
   / Hydraulic scissor lift won't go down. #1
Yander
Ohio
Yanmar SA425 - Kubota G6200 GT
I bought this BendPak lift back in November and finally got the ambition and a reason to put it together. Went together smoothly, lifted fine but now it won't go down.
Any ideas here? It was when I was giving it a test run with no car on it.
Here is a pic of the buttons to raise and lower. I have the steel stop out but it will not go down at all. Frustrating, I have a break job to do this weekend.
Thanks
   / Hydraulic scissor lift won't go down. #2
In the middle, between the 2 cylinders is a safety lock. It must be released to let it come down. The directions should show you how to release the safety lock. You may have to raise it a bit more to release the latch.
Thanks, yes the safety lock is out.
   / Hydraulic scissor lift won't go down. #4
Try putting some weight on it when trying to lower it..
I just found this. This could be my problem. We didn't know if we should check the level with the dipstick screwed in or not (Nothing in the manual). I may have under filled it.
It turns out that I'm an idiot and it was the mechanical lock. I thought the little thing that flips out was the lock when it was really what allows the actual lock to ride over the lock points.
It took me a lot of steps to figure it out. To the point I had hydraulic lines off and it still wouldn't go down. Which caused me to say, it has to be mechanical and looked closer.
I will say, the manual is absolute crap. It does not explain this whatsoever. Anyway, mystery solved thanks George and others who commented.
   / Hydraulic scissor lift won't go down. #7
No oil would prevent lift from raising.
   / Hydraulic scissor lift won't go down. #8
Glad you got it fixed! I was reading the first comment, and thought to myself, the lock isn't releasing!
I found a used lift in a friends shop that I was helping him clean out, and all it needed was a cylinder rebuilt. With the lock on the cylinder, that turned out to be an expensive "freebie" because I had to have a new cylinder fabricated!
They are handy little things, I use mine mostly for a work bench!
David from jax
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
KUBOTA U48-5 EXCAVATOR (A51246)
KUBOTA U48-5...
2022 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2022 CATERPILLAR...
4' X 8' X 1/8" THICK DIAMOND PLATE STEEL SHEETS (A51247)
4' X 8' X 1/8"...
UNUSED AGT 54" EXCAVATOR HYD BRUSH CUTTER (A51248)
UNUSED AGT 54"...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
