'Corner Crossing' at checkerboard Fed/Private survey corners may be a protected right - or not
/ 'Corner Crossing' at checkerboard Fed/Private survey corners may be a protected right - or not
My great-grandparents lost a farm they had homesteaded when that checkerboard railroad land grant was put through their land subsequently. They and neighbors raise $20k, a huge sum in 1870, for an attorney in DC. He disappeared and they had to start over elsewhere.
But eventually they did ok, and gave developed farms to each of their several sons.
All railroad land was given like this. Why, I don't know as it's only created issues later on.
It took huge incentives for any private company to build the first transcontinental railroad across near-useless western desert.
The partnership of Gold Rush barons including Leland Stanford (Stanford U) were able to persuade Congress to give checkerboard land as part of the payment for the project.
The value of their new, developable land made the railroads into an even more powerful factor influencing Congress.
/ 'Corner Crossing' at checkerboard Fed/Private survey corners may be a protected right - or not #23
And then the railroads built in a circuitous route to increase the miles and the land they were granted.
/ 'Corner Crossing' at checkerboard Fed/Private survey corners may be a protected right - or not #24
This case has been percolating along for quite some time.
@Snobdds Thanks for the local insights and behind the scenes color. Have you seen the corner in question? I've read a few articles, and none of them have a photo. I'm just curious how the fencing is actually done.
All the best,
Peter
/ 'Corner Crossing' at checkerboard Fed/Private survey corners may be a protected right - or not #25
Well, I know him so...
People put a lot of faith in google.
And a lot of faith in people posting on websites such as this. The info on the owner of the property is a matter of public record.
The property owner
*“has a history of multi-million-dollar philanthropy, a long track record of conservative political donations, a complex inventory of land transactions in Carbon County — including the donation of several conservation easements — and a willingness to litigate.”
*from Wyofile.com — WyoFile is an independent, member-supported, public-interest news service reporting on the people, places and policy of Wyoming. The organization incorporated in 2009 as a Wyoming 501(c)3 nonprofit, and is a member of the Institute for NonProfit News.
/ 'Corner Crossing' at checkerboard Fed/Private survey corners may be a protected right - or not #26
The federal and state governments made far more then the value of the granted land in reduced freight rates and increased taxes.
One example:
Bruce
/ 'Corner Crossing' at checkerboard Fed/Private survey corners may be a protected right - or not #27
I can picture the scenario I think. They cross a corner where they theoretically aren’t touching his ground with their feet but their shoulders arms etc are trespassing. If I’m picturing it correctly he is correct, it would be trespassing and if he fenced his ground they could only get across it by climbing his fence.
Lots of things going on here from a legal point of view, easement by necessity, adverse possession, estoppel and some other things I can’t think of. The bottom line is he is just being a pain in the behind.
Here is pic of the corner in question.
/ 'Corner Crossing' at checkerboard Fed/Private survey corners may be a protected right - or not #28
This is a BS
One example:
Bruce
Ancient history. The public land is STILL publicly owned land.
/ 'Corner Crossing' at checkerboard Fed/Private survey corners may be a protected right - or not #29
I agree. I got sidetracked about the RR land grant comments.
Bruce
/ 'Corner Crossing' at checkerboard Fed/Private survey corners may be a protected right - or not #30
Pole vault?
Helipad to fly in and out?
Tunnel???
/ 'Corner Crossing' at checkerboard Fed/Private survey corners may be a protected right - or not #31
Is this the same land owner?
Hasn't this already been decided?
/ 'Corner Crossing' at checkerboard Fed/Private survey corners may be a protected right - or not #32
One thing to keep in mind a boundary line has no width and a boundary corner has no dimension, they are infinitely small. I get why the guy thinks people are trespassing, in theory they are.
There is a legal principal, which of course I can’t think of the actual term, that maybe you have the law on your side but the damage to you is so minimal and the damage to the other party is so great, you lose. That kind of seems to be the case here.
There is a legal principle...
And more specifically, that link I put above to a lawyer's discussion of the federal Unlawful Enclosures Act of 1885 is relevant here. iIt says the Act guarantees that access to public land shall not be prevented by private owners when (only when) the only usable route to that public land is through the private property. Not a fundamental principle, but an explicit law enacted to keep public lands accessible.
The Act of 1885 seems to apply in this case, and more generally, is written to say if a cliff, river, factory, something blocks what would be the only access, then the public has a right to cross the private land in the manner that least harms the private landowner.
/ 'Corner Crossing' at checkerboard Fed/Private survey corners may be a protected right - or not #34
Pole vault?
Tunnel???
Tunnel would cross his land. What some are doing is carrying ladders in so that they can cross the corners without touching his land. They are dedicated hunters… imagine packing an elk out over a ladder.
/ 'Corner Crossing' at checkerboard Fed/Private survey corners may be a protected right - or not #35
He should be careful with his insistence. If they wanted, the state could 'take' the corners and then that issue goes away. I'm a big proponent of private property rights and would hate to see that. Unless the hunters are damaging his property/fences, he is making a mountain out of a molehill. Most reports seem to be that hunters have been careful not to infringe.
He should be careful with his insistence. ...he is making a mountain out of a molehill.
The videos that Slowpoke Slim linked, above, add an attorney's interpretation to the WyoFile original reports of the issue. But that Eastern attorney doesn't seem to recognize the westerner's perspective that dominates the comments on YouTube below the video, and I think this is the essence of the issue:
This landowner, who is said to use lawsuits generously in his Wyoming real estate ventures, names $7m as his damages because feels the value of his 28,000 acre hunting preserve is diminished by losing his exclusive right to control access into the 6,000 acres of public land within his outer perimeter. So now he can only claim he controls 22,000 acres, and this diminishes what he thought was the overall value of his ranch.
His is a nonsense assertion. He never owned the 6,000 acres so he has lost nothing by the court re-affirming the public's right to use the public land.
/ 'Corner Crossing' at checkerboard Fed/Private survey corners may be a protected right - or not #37
Everyone in Wyoming that owns land was watching this case. From my perspective, most did not want him to prevail. If he did, the fences all across the state would need to be surveyed to see just exactly where they were to prevent litigation. Guys that put in fence lines, don't necessarily go right down a property line. I think it's reasonable to have a little wiggle room in property boundaries out in the middle of nowhere.
In general everyone thought it was a little silly suing these guys for trespassing.
A fool and his foolish money are easily departed...
/ 'Corner Crossing' at checkerboard Fed/Private survey corners may be a protected right - or not #38
The videos that Sowpoke Slim linked, above, add an attorney's interpretation to the WyoFile original reports of the issue. But that Eastern attorney doesn't seem to recognize the westerner's perspective that dominates the comments on YouTube below the video, and I think this is the essence of the issue:
Whether the lawyer is an "easterner" or not is completely irrelevant.
1. The landowner LOST in federal court.
2. The landowner DROPPED his claim.
Nothing left to talk about.
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
2011 Chevrolet Impala Sedan (A59231)
2011 Chevrolet...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A59230)
2016 Peterbilt 579...
2021 METSO QUOTEC NORDTRACK S3.7 MOBILE SCREENER (A60429)
2021 METSO QUOTEC...
