Fuel filter changed, now won’t start??
   / Fuel filter changed, now won’t start?? #1
Eggsiam
Bryant, Washington
1984 Iseki tu1600 4wd mini tractor
Can somebody help me out here. 1984 Iseki tu1600, I changed the oil, air and fuel filters as well as oil. Now it won’t start. Any ideas? Do I need to bleed the fuel lines?? HELP PLEASE
   / Fuel filter changed, now won’t start?? #2
I know nothing about your specific machine but bleeding the air out of the fuel lines is likely your solution. Once air gets into the injector lines it just keeps getting compressed and can’t pop the injectors.
Your operators manual should provide you the info to do it.
   / Fuel filter changed, now won’t start?? #3
I agree with Chewwy. Follow the manual's instructions exactly. They will probably give a sequence to the bleeding, not just the locations. I had a Mitsubishi tractor with three separate bleed locations. You could not skip any or shuffle the order.
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
Rock wood travel trailer (A51694)
Rock wood travel...
2020 John Deere 8R 410 MFWD Tractor (A53342)
2020 John Deere 8R...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
