YM1700 - Broken fork Hi -Lo. Break tractor apart to replace ?
   / YM1700 - Broken fork Hi -Lo. Break tractor apart to replace ? #1
1redroan
Yanmar YM1700 1975
Do I have to break apart the tractor to replace fork - Hi Lo lever shift. If not, I know to remove shift cover, then what do I do ?
Oh -- big howdy to all, I'm new to the FORUM
   / YM1700 - Broken fork Hi -Lo. Break tractor apart to replace ? #2
Not for sure which part you are wanting to replace, might take a look at this. Welcome to the forum.
fork inside transmission, moves gear in and out of Hi or Lo
I added a picture, sorry trying to learn how to use forum
   / YM1700 - Broken fork Hi -Lo. Break tractor apart to replace ? #5
   / YM1700 - Broken fork Hi -Lo. Break tractor apart to replace ? #6
If it is popping out of gear it will need more than a shift fork. A common problem is the dogs on the side of the gears that engage the adjacent gear get worn and pop out under load. Both gears, the one with the dogs and the one with the pockets for the dogs will wear and will need replacement.
"popping" out of high gear
   / YM1700 - Broken fork Hi -Lo. Break tractor apart to replace ? #7
   / YM1700 - Broken fork Hi -Lo. Break tractor apart to replace ? #8
I see I am quoted in both the linked posts!
12 years later now, an update: I can report that the bungee holding the range selector in high or low is still working 99% of the time. A couple of times per year it will jump out, at maximum load and when lurching over rough ground.
Since this YM240 is now used only to run its attached backhoe there's no urgent reason to split the tractor and replace several expensive parts.
Long ago an original Yanmar dealer posted that all related gears have to be replaced to fix the range selector jumping out of gear. Anybody know if parts are available?
   / YM1700 - Broken fork Hi -Lo. Break tractor apart to replace ? #9
Incidentally - I got the idea of the shifter bungee from a friend whose father raced jalopies long ago. He said in those $100 claimer junkers everyone welded a J-hook to the dashboard to hold the floor shift lever in second gear.
Something similar, rigid, in place of a flexible bungee might be a good-enough fix to go another decade.
   / YM1700 - Broken fork Hi -Lo. Break tractor apart to replace ? #10
It is possible to save the gears if the only problem is the rounded dogs. Shops have been undercutting dogs on gears for better engagement for many years now.
   / YM1700 - Broken fork Hi -Lo. Break tractor apart to replace ? #11
194150 - 181923 Hi Lo Shift Lever - nothing definitive here on installing - anyone have any experience IN replacing the shift lever?
   / YM1700 - Broken fork Hi -Lo. Break tractor apart to replace ? #12
Did you read all of this thread?
2020 CATERPILLAR 336 EXCAVATOR (A60429)
2020 CATERPILLAR...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
BETTER BUILT FUEL CELL (A58214)
BETTER BUILT FUEL...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
