Kioti Sun Visor and Antenna Parts
   / Kioti Sun Visor and Antenna Parts #1
spindlewood
Northern Idaho
Kioti DK40SE HST Cab
The sun visor no longer works. I'm not actually sure how it's supposed to work or where to get parts.
Does the metal bar turn in the visor or does the visor rod turn in the plastic clip/sleeve? I can't find anywhere that I can get replacement clips/sleeves.
The antenna also broke from something low lying. Same problem searching for an antenna wand.
Any sources for either of these?
   / Kioti Sun Visor and Antenna Parts #2
Found this on Michigan Irons website. Based it on the dk40se cab tractor in your profile...
   / Kioti Sun Visor and Antenna Parts #3
That's the sun visor itself... Look around and you can probably find just the brackets...
   / Kioti Sun Visor and Antenna Parts #4
I seriously doubt it. That stuff will almost always be OEM. Far as the antenna goes, antenna replacement whips are all over the net and Amazon if you do that site.
   / Kioti Sun Visor and Antenna Parts #5
I meant look around on the parts list... He might be able to find the brackets themselves. I was referencing that they seem to show the visor is still available, so the brackets may be available still also.
Thank you for the link. It helped me zero in on the bracket part. Decided to call my dealer and he verified it was one of those (I believe T4930-80143). I hope it isn't a "fixed" visor - that it can drop down and be put back up. We'll see.
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
UNUSED CFG INDUSTRIAL MX20R EXCAVATOR (A51247)
UNUSED CFG...
UNUSED FUTURE BD43 HYD BACKHOE ATTACHMENT (A51248)
UNUSED FUTURE BD43...
LMC G500-500A LOT IDENTIFIER 94 (A53084)
LMC G500-500A LOT...
PALLET OF SITE FENCE STABILIZERS (A51248)
PALLET OF SITE...
