Suggestions on 20” pro saw
   / Suggestions on 20” pro saw #11
You qualify!!! Treat yourself!!! 😁 I dont cut every day either but when I do, it is hot and heavy and love cutting through wood like butter.
   / Suggestions on 20” pro saw #12
Another Pro saw fan here. I have a 20" on my 361, and it has handled everything here with no issue for a decade+. A 262 can do the same, just a bit slower, but it will be lightener than a 362. Just one example:
   / Suggestions on 20” pro saw #13
I've had a Stihl 261 since maybe 2012 or 2013. I've had no issues with it other than wear items, I've found it powers an 18" 3/8 chisel chain very well in hardwoods, some prefer a 20" in 3/8 pitch.
I wouldn't be afraid of the comparable Husqvarna or Echo chainsaw, dealer support in my area for all three is great.
I know several people with the Husky rancher saws and I've had Stihl Farmboss series saws, they have all served them/me well.
   / Suggestions on 20” pro saw #14
   / Suggestions on 20” pro saw #15
I'm a big Echo fan. For the same money as the Stihl you can step up to a CS680 Echo. I've had mine for 7 years, best saw ever. Loaned it out to a sawyer friend and he had to buy his own. He still runs Stihls and Huskys, but new saws for him will be Echos.
The 680 is a great felling/bucking saw, not so good for limbing. I switch to a small saw for the small stuff.
My dad was a big Echo saw fan, too.
I still had his old 6 series after he died, but it would have been a project to rebuild.
I will check out the 680.
On edit: at 14+ lbs, the 680 may be a bit heavy for limping & bucking.
My big Makita/Dolmar is a similar saw.
Good lookin saw though!
   / Suggestions on 20” pro saw #17
You can't go wrong with a 261 if you are just cutting occasionally.
I thought the “black stripe” 261C was a “pro” (constant use) saw?
   / Suggestions on 20” pro saw #19
I believe all 261's will be the pro model. I think the only option you can get is to either get the M-tronic or the old tunable carbs.
I still like the tunable carbs that I don't need software to diagnosis. Some like the M-tronic where they don't have to mess it tuning it.
Either way it's a good saw. I think the husky equivalent is the 550xp, also a great saw.
OK, I was thinking you thought it was an occasional use (homeowner) model.
I WOULD like to get the tunable carb. Only complaints I read were regarding the M-tropic.
New Holland B95 Backhoe (A50490)
New Holland B95...
2007 VOLVO VNL DAY CAB (A52577)
2007 VOLVO VNL DAY...
2006 Dodge Ram 3500 4x4 Pickup Truck (Diesel), VIN # 3D7LX38C36G220767 (A51572)
2006 Dodge Ram...
18ft Refrigerated Box for Cab and Chassis Truck (A51573)
18ft Refrigerated...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
