Suggestions on 20” pro saw
   / Suggestions on 20” pro saw #11
You qualify!!! Treat yourself!!! 😁 I dont cut every day either but when I do, it is hot and heavy and love cutting through wood like butter.
   / Suggestions on 20” pro saw #12
Another Pro saw fan here. I have a 20" on my 361, and it has handled everything here with no issue for a decade+. A 262 can do the same, just a bit slower, but it will be lightener than a 362. Just one example:
   / Suggestions on 20” pro saw #13
I've had a Stihl 261 since maybe 2012 or 2013. I've had no issues with it other than wear items, I've found it powers an 18" 3/8 chisel chain very well in hardwoods, some prefer a 20" in 3/8 pitch.
I wouldn't be afraid of the comparable Husqvarna or Echo chainsaw, dealer support in my area for all three is great.
I know several people with the Husky rancher saws and I've had Stihl Farmboss series saws, they have all served them/me well.
   / Suggestions on 20” pro saw #14
   / Suggestions on 20” pro saw #15
I'm a big Echo fan. For the same money as the Stihl you can step up to a CS680 Echo. I've had mine for 7 years, best saw ever. Loaned it out to a sawyer friend and he had to buy his own. He still runs Stihls and Huskys, but new saws for him will be Echos.
The 680 is a great felling/bucking saw, not so good for limbing. I switch to a small saw for the small stuff.
My dad was a big Echo saw fan, too.
I still had his old 6 series after he died, but it would have been a project to rebuild.
I will check out the 680.
On edit: at 14+ lbs, the 680 may be a bit heavy for limping & bucking.
My big Makita/Dolmar is a similar saw.
Good lookin saw though!
   / Suggestions on 20” pro saw #17
You can't go wrong with a 261 if you are just cutting occasionally.
I thought the “black stripe” 261C was a “pro” (constant use) saw?
   / Suggestions on 20” pro saw #19
I believe all 261's will be the pro model. I think the only option you can get is to either get the M-tronic or the old tunable carbs.
I still like the tunable carbs that I don't need software to diagnosis. Some like the M-tronic where they don't have to mess it tuning it.
Either way it's a good saw. I think the husky equivalent is the 550xp, also a great saw.
OK, I was thinking you thought it was an occasional use (homeowner) model.
I WOULD like to get the tunable carb. Only complaints I read were regarding the M-tropic.
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A53472)
2022 NEW HOLLAND...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
New Land Honor 5400 LB Ratchet Binder And Chains (A53002)
New Land Honor...
1/2 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/2 '' Wolverine...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
