Doubledeuce
Hello all. About to order a t654 power shuttle from my dealer. According to him there's no option to order one with a creeper gear. Does that come standard or is it not available?
Thanks! So does the creeper gear come as standard equipment? My dealer said there's no option on his build sheet to order it.The specs list a 24x24 transmission, so should indeed have Creeper gears.
Got this from the operators manual, also found on TYM website:
Yes, I would say so. TYM often includes a lot of standard equipment that would be an option on other brands.Thanks! So does the creeper gear come as standard equipment? My dealer said there's no option on his build sheet to order it.
Makes sense. I hope you're right. ThanksSometimes terminology can be the problem. Not sure if this is the case, but with that many gear levels TYM may have included the "creeper" speeds in the lowest range. That seems to be what this dealer indicates in the description.
TYM T654PSC Cab Tractor/Loader - Keno Tractors
TYM T654PSC Cab Tractor/Loader with its Power Shuttle Transmission offers maximized power and ease of control. Bringing you the best of both worlds.www.kenotractors.com
On my T700 it has on the Range selector 4 ranges LL, L, M, H 16 F, 16 R, I would see if you can find a picture of the Range selector stick in that tractor. If you have 4 ranges first one should be your creeper gear.Thanks! So does the creeper gear come as standard equipment? My dealer said there's no option on his build sheet to order it.
On my T700 it has on the Range selector 4 ranges LL, L, M, H 16 F, 16 R, I would see if you can find a picture of the Range selector stick in that tractor. Should have 4 ranges! Congrats on an awesome tractor! Really like that Deutz motor.Thanks! So does the creeper gear come as standard equipment? My dealer said there's no option on his build sheet to order it.
