Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #22,301
My full size skid steer would have been optimal for this job but I didn’t want to go get it from a job and haul it back. This stand on machine continues to impress me. That’s a 20” bar on the saw for scale and the log is probably 12ft long. The log in the last picture is a 14ft hickory.
   / Tractors and wood! Show your pics #22,302
I had a couple of trees fallen in the storm. My daughter volunteered to help me to do the most difficult part 🤣
   / Tractors and wood! Show your pics #22,303
I don't know if it applies on a trailer deck, but the way I manage heavy rounds is to place the dog of the saw in the middle of the round, make two 45* saw cuts on opposite sides of a round standing up of just enough depth of cut to hold two wedges to either side. Couple, 3 whacks and the round is split. Very fast. You can do 10 of these in about 10 minutes w this method.
The problem as I see it here however, is perhaps the deck being too flexible and thus absorbing the whacks.
Maybe you could cut say less than half way and then insert wedges?
I guess I don't see the need when what we are doing now works pretty darn good. I will probably change things when we can no longer do it, we aren't getting any younger.
Even chainsawing them all the way through really isn't a big deal, and I do, do that sometimes.
SR
   / Tractors and wood! Show your pics #22,304
I'm impressed as well considering that piece is approaching a ton or at least 1700 lbs if dead..
What do those things weigh?
   / Tractors and wood! Show your pics #22,305
SR
I have always enjoyed your posts. But as a old man, I wonderred how long you can keep doing it your way.
Dealing with rounds over 20” in diameter gets tough and you handle stuff bigger than that. Being younger and full of piss and vinegar is a far away memory for me.
it will be interesting to see how you adapt….if I live long enough…lol.
   / Tractors and wood! Show your pics #22,306
I assumed more like 2500 pounds or at least a ton just from handling it. That model skid steer is 3600 pounds.
   / Tractors and wood! Show your pics #22,307
I’ll put them on my splitter up to about 24” diameter. Much bigger than that and the half piece is too heavy to get back on the splitter. I have a log lift on my splitter and rolling a 24” on level ground isn’t that bad. I’ll noodle down the big rounds but I find when you do that it’s about as easy to 1/4 them. If you cut the big rounds in half they’ll land on the flat spot trying to move them and they’re heavy to get back up.
   / Tractors and wood! Show your pics #22,308
Don, I've read your post and many times you talk about being in your 70's, here's a news flash for you, I'm in my 70's too. That's why many times I have a helper. When I'm alone, I saw them down to quarters.
What I'm doing right now works pretty good for me, if I have to change something later, I have no problem doing so.
SR
   / Tractors and wood! Show your pics #22,309
Don, I've read your post and many times, and you talk about being in your 70's, here's a news flash for you, I'm in my 70's too. That's why many times I have a helper. When I'm alone, I saw them down to quarters.
SR
You are a better man than I am!! Lol
   / Tractors and wood! Show your pics #22,311
I want one, I'll add it to my Christmas list
   / Tractors and wood! Show your pics #22,312
Last evening, it was time to trim some trees,
Then today it was off to my second story room, everyone calls my "treehouse", to do some eve extension, and YES it was hot today!
I wanted the eve to cover my stairs, so we got-r-done!
I love the view from the "treehouse",
I'll add a bit of bracing under that eve later...
SR
   / Tractors and wood! Show your pics #22,313
Slightly off topic:
Not sure if any of you wear boots with chainsaw cut protection, But Haix is offering $100 off their XR200 Chainsaw boot (European class 1 cut protection, 7" height). They normally sell for $345, but with the discount are now at $245.
Go to: HAIX Bootstore
and use this Code at checkout: AIRPOWER100
I owned some rubber Jonsered boots for years ago which I never wore. They were great if I was working in wet conditions, but just too darn uncomfortable if I had much walking to do. The Haix XR200 boots look like a leather hiking boot and are very comfortable. I've owned - and wore out - dozens of pairs of hiking boots over the years and put thousands of miles on them, and these are as comfortable as the best of them. They are holding up well. I've owned these for about 8 or 9 years now. I'm not a full time logger, but I spend a fair amount of time in them logging, firewood harvesting, and doing trail construction & maintenance in all seasons. I'm very happy with them.
Haix also makes Their Protector Prime (9" tall) and Protector Ultra (8" tall) chainsaw boots with the higher class 2 protection. Back when I bought my XR200 boots, the only other option was the Prime. 9" was too tall for my taste, so I went with the XR200 boots. If I were buying today, it would be either the Ultra or another pair of the XR200. I do think the tread on the sole of the Ultra and Prime boots is a design that gives better traction, but they also felt a bit "clunkier" on my feet when I tried them on at a logging expo here in Vermont a few years ago. It may be that I would not notice that, once I got them broken in.
EDIT: In my experience, the XR200 boots run true to size. I wear a size 9 medium width sneaker, and that size in the boot fit me perfectly. The Haix folks tell me that the Prime and Ultra boots tend to run big. Most people order them a half size smaller than their regular shoe.
   / Tractors and wood! Show your pics #22,314
I have a pair of the lighter weight zip up boots from Haix. They are super lightweight, the zipper still works great and they're cool in summer. 1 downside is the soles telegraph the terrain at times. Overall decent, I got them on factory seconds deal & I couldn't find why they were rejected as firsts.
   / Tractors and wood! Show your pics #22,315
Are those chainsaw cut protection boots? If so, I'm not familiar with them.
   / Tractors and wood! Show your pics #22,316
No, they're not, just tossing in my 2 cents on Haix boots.
   / Tractors and wood! Show your pics #22,317
OK, time to put the wheel back on my tractor and get it back to work. First, I bolted the center on,
then on goes the rim,
Everything bolted up as it should, so time to finish loading my wagon,
and sawing the logs to firewood lengths,
and once loaded, I headed to the splitting area.
Remember, you ain't loaded unless you're overloaded!! lol
SR
I still can’t believe that it wasn’t covered under warranty. :D
   / Tractors and wood! Show your pics #22,319
My mini excavator is still my favorite tool for cutting firewood but this stand on skid steer is a close second. The narrow grapple doesn’t waste a lot of room that you can’t cut and it’s super fast getting on and off of this thing. Climbing on and off a machine 50 times when you’re shuffling logs gets tiring.
   / Tractors and wood! Show your pics #22,320
Well, it was another fantastic day weather wise here, sunny 70s with a breeze, and my buddy wanted to finish splitting this wagon load we cut and got started on a couple weeks ago,
I said before how I HATE these metal baskets and have turned them down when offered to me. One of the biggest reasons is, having to close the pallet forks a bit to move them, but I figured out a cure for that, so I'm now trying them again,
This works very well, so one problem solved!
Anyway, with an empty wagon, off we go to cut another load from the two BIG oaks I cut down some time ago. One tree is now all cleaned up, so we started taking all the limb wood from the second one,
Some of the limbs were quite big too,
and soon we had another big load to split!
AND there's more than another big load yet to get!
but that's a job for another day!
SR
2019 GALYEAN...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52707)
(INOP) 2016...
2018 KOMATSU WA200-8 WHEEL LOADER (A60429)
2018 KOMATSU...
2024 Timpte 40ft Hopper (A56438)
2024 Timpte 40ft...
Year: 2012 Make: GMC Model: Acadia Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 188,471 Plate: (A59231)
Year: 2012 Make...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
