X758 Overheats after an hour
   / X758 Overheats after an hour #1
Oconee1868
JohnDeere 4200 & John Deere x758 2017 4wd
My x758 will overheat after an hour of operation especially mowing heavy grass. Air filter Clean
   / X758 Overheats after an hour #2
Check the radiator screen and the radiator for debris. The screen does not stop it all. Also check your coolant level.
Dave
Dave
Thanks ... I keep the screen clean but I will make sure the Radiator is double clean. Coolant is full.
   / X758 Overheats after an hour #4
I take a air wand and blow thru the radiator from the engine side (reverse) every time after mowing.
   / X758 Overheats after an hour #5
Kubota L4600. Had to take radiator off due to a leak. I set it at 45 degree to clean it before I took it to the radiator shop. I always clean after mowing. I probably washed out a pint or more of dirt with the hose. Sprayed each side bout 3 times before it became clean. And this was after I cleaned it after I mowed. I'll know to do a better cleaning next time.
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
2017 GRAND DESIGN RECREATIONAL MOMENTUM (A53843)
2017 GRAND DESIGN...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2005 Sterling Acterra Tender Truck (A53473)
2005 Sterling...
CABINET OF HOSE ENDS (A53843)
CABINET OF HOSE...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
