etpm
- Joined
- Jun 30, 2021
- Messages
- 2,274
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
My YM2310 is over 40 years old so of course it develops an oil leak. I noticed some oil on the ground at the rear of the tractor, couldn't see the source, so I washed the back end of the machine, drove it around for a bit, and then looked for a fresh leak. It turned out that the leak was coming from the top of the main rear end casting, where the casting is bolted to the other big casting that acts as a cover, among other things. At first I thought it was a gasket but the real culprit was loose bolts. 7 or 8 of them. Not real loose, tighter than finger tight but easy to turn with a wrench. After tightening all the loose bolts and checking all the other bolts I could see the leak has stopped. I got lucky that I noticed the leak before the bolts became loose enough to allow things to shift and cause damage. Ya gotta check stuff on tractors on a regular basis and I just got a really good lesson for a really good price.
Eric
Eric
