arto98607
- Joined
- Aug 27, 2014
- Messages
- 1,518
- Location
- Southwest WA
- Tractor
- Kubota F3060, Grasshopper 721D, Ford 1310, John Deere 440 ICD, John Deere 300 & 430
We are having bunch of "hazard trees" trees removed from our property by loggers and they will remove all the smaller stumps, which can be relatively easily removed by the JD excavator in these photos, but I will be left with many large Douglas Fir stumps to deal with, many of which are at least 44 inches diameter where the tree was cut down.
I also have many other stumps from previous tree removal to grind down.
In order to deal with these large stumps I decided to buy used Vermeer SC362 stump cutter, which I brought home last week and decided to start a thread here in order to describe how well this will work out.
My first step was to order set of spare replacement belts & idlers and set of Greenteeth "Performance Upgrade" kit since their price looked reasonable and members here have given pretty good reviews. Also couple of OEM tooth pockets had been damaged from previous use.
Nothing against Vermeer Yellow Jacket setup, just decided to try switching from 16 cutting teeth to 6 and see how well that works out?
I also did some regular maintenance like engine oil change, belt tightening, lube etc.
I will keep you posted!
Vanguard 35 hp
Vanguard 35 hp
