2535 century Diesel tank neck broken out
   / 2535 century Diesel tank neck broken out #1
Halfway66
Century zetna 35
Dealer wants over $500 for replacement tank? Any suggestions? I’ve already tried plastic weld! No go!
   / 2535 century Diesel tank neck broken out #2
Maybe you can wrap it with fiberglass?
   / 2535 century Diesel tank neck broken out #3
Can you take the tank off and take it to a repair shop in your area? Maybe it can be fixed. If not, maybe they can make you one out of aluminum to take it's place?
   / 2535 century Diesel tank neck broken out #4
Depending on how aesthetically pleasing you want I'm aware of aftermarket aluminum sleeves made for plastic fuel and oil tanks of power sports equipment, snowmobiles etc (particularly Arctic scrap) sorry cat fans lol. Depending how handy you are could probably make your own steel or aluminum sleeve with a collar fastening to top of tank with mechanical fasteners and solvent resistant sealant. Imo and experience doing this to plastic fuel tanks it worked for me and is a cheap backwoods hack. Apologize for no pics.
   / 2535 century Diesel tank neck broken out #5
Any update on this?
FYI Forum Members.
I have successfully repaired several plastic fuel tanks in the past.
Regarding plastic weld, I would suggest the welding rod over the liquid weld. I gave up on the liquid more than a decade ago. I used a heated iron and it made the broken pieces one material. I used the correct rods with a thermal heat process. HF did not not include the HDPE in their plastic weld kit. I purchased my HDPE rod kit online with an included heating iron. One time I found enough tank material from the unfinished seam edges on the tank and I used a soldering iron to make the repair. I also think, a new sacrificial fuel can could be used to patch large areas if needed, but I have not tried this yet.
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2024 JOHN DEERE FC20M LOT NUMBER 71 (A53084)
2024 JOHN DEERE...
