Hillside brush cutting power and stability 425/1430/1445
   / Hillside brush cutting power and stability 425/1430/1445 #21
Thank you for taking the time to explain why a PT has more stability. I was thinking a PT would be more stable due to being lower to the ground than a normal farm tractor, but your explanation helps me understand there's more to it.
It's worth seeing if you can test drive someone's machine or taking a trip to Tazewell to see everything they offer. I hear they are quit friendly. ;)
I need to stick close to the house these days due to having a senior dog who needs help getting up to go out to potty.
   / Hillside brush cutting power and stability 425/1430/1445 #23
I suspect that will be my wife having to stick around to help me in the future! :ROFLMAO:
They make adult diapers.
   / Hillside brush cutting power and stability 425/1430/1445 #25
In all seriousness, we have a couple cats and a tortoise. Someone has to watch the tortoise daily. The cats, not so much. So we always have to find someone to watch the house when we go away.
And just like that, ruined the seriousness of the whole thread with potty talk
But stick around folks to find out how fast downhill we can go.
   / Hillside brush cutting power and stability 425/1430/1445 #30
Well, that's the nice thing about the automatic brake on the 1445!
I would echo @m5040's comments on stability. The center articulation keeps all 4 wheels on the ground almost all the time. When you pick up something too heavy, a rear wheel or two will lift, (and the front load will droop), but the rear end is connected solidly to the heavy front half by two hydraulic cylinders and the knuckle joint. It feels more like a polite "gosh that wasn't what I intended", rather than a "OMG, HELP!! I'm going to die."
Perhaps you can find someone to dog sit for a bit? Or bring your senior along for the ride?
Good luck,
Peter
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
Miles read : 112,969 (A50323)
Miles read ...
2006 JLG 2030ES 20ft Electric Scissor Lift (A54811)
2006 JLG 2030ES...
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
2012 Chevrolet Cruze Sedan (A53424)
2012 Chevrolet...
