Strange Symbols Painted on Ground
   / Strange Symbols Painted on Ground #1
wmfamily
New Haven, MO
JD 4066M
I found the attached painted on the ground at the end of my driveway. I only go to my property every couple of weeks but from the looks of it they were painted fairly recently. Does anyone have any ideas? They look something like survey markings but I didn't find anything else nearby.
   / Strange Symbols Painted on Ground #3
Yep. Utility locate markings.
   / Strange Symbols Painted on Ground #4
It looks like somebody has called in a utility locate. I don’t know the abbreviations at the top but the bottom is CLR which means clear. The orange is phone and the red is usually power.
Here, power is white, blue is water. I couldn't tell you what the others are.
   / Strange Symbols Painted on Ground #5
Purple=reclaimed/grey/raw water
Blue=water (potable)
Green=sewer, (sanitary gravity or Forcemain); storm sewer is technically not a utility, but a roadway facility, and are not covered by locate rules
Red=electric
Yellow=gas
Orange=telecom (coax, copper, fiber, leaded air, all telecoms)
Pink=surveyor
White=contractor marking where he needs locates
These are set by the Damage Prevent Guidebook in Fla, (think it's FS 556 or something) may differ state to state
   / Strange Symbols Painted on Ground #7
There does seem to be a contradiction at times for effluent lines; I've seen them marked as blue, green, or purple; (water treatment waste, paper plant discharge, brewery discharge, ect)
   / Strange Symbols Painted on Ground #8
Red=electric
Yellow=gas
Pink=surveyor
It's funny. The local power company used white to mark power pole locations for install.
Local electrician marked in white as well for his guys to place the temporary pole as well as rv and septic pedestal.
Local water company marked in blue for their install locations.
   / Strange Symbols Painted on Ground #10
Could that be the power company 'white lining' for the location of their excavation, before they call in locates?
2008 JLG 800AJ MANLIFT (A52707)
2008 JLG 800AJ...
1977 Gleaner A630 Corn Head (A57024)
1977 Gleaner A630...
2013 Ford F150 4X4 Pickup Truck (A53422)
2013 Ford F150 4X4...
2025 XKH39 39in Hydraulic 4-Way Clamshell Skid Steer Bucket (A55851)
2025 XKH39 39in...
Utility Trailer (A52377)
Utility Trailer...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
