Rear tire bolt info 2 bolts have snspped off r they presed in or threaded on my 99 l42
   / Rear tire bolt info 2 bolts have snspped off r they presed in or threaded on my 99 l42 #1
michael chito
99 l42 kubota
R rear bolts on my 99 l42 threaded or pressed in both bolts hsv snapped off ???
   / Rear tire bolt info 2 bolts have snspped off r they presed in or threaded on my 99 l42 #2
Are you talking (wheel) lug bolts.... If so adjacent bolts/studs should give you a clue....
IF you have lug nuts on threaded studs showing then studs are pressed into flange on axle, if you have bolt heads (no threads showing) then the lug bolts are threaded into flange on axle....
   / Rear tire bolt info 2 bolts have snspped off r they presed in or threaded on my 99 l42 #3
For cars, I don't think I've ever seen wheel studs threaded into the hub.
However, if you can see the back side of the hub/flange, if the stud is pressed in, you'll see a mushroom head on the back side that is larger than the actual bolt diameter. And no flats or Torx for any type of wrench.
A Caliper would tell you the answer very quickly.
   / Rear tire bolt info 2 bolts have snspped off r they presed in or threaded on my 99 l42 #4
What model of tractor do you have? L42 is not a valid Kubota model. Once we have a correct model we can provide pertinent advice. If you have a nut on the outside then the fastener is a stud and they are press fit in. If they fastener on the outside is a bolthead then they are lug bolts and are threaded in.
   / Rear tire bolt info 2 bolts have snspped off r they presed in or threaded on my 99 l42 #6
VW does that. I think some other German cars do as well. It's kind of a pain when you're mounting a wheel.
My Kubota B7100 had a mix of bolts and studs on the front hubs, from the factory.
   / Rear tire bolt info 2 bolts have snspped off r they presed in or threaded on my 99 l42 #7
Eartly VW (Beetle, Ghia, Thing) does not use wheel studs VW uses bolts, if there are stud in early VW hubs they are after market and are not a standard feature...
   / Rear tire bolt info 2 bolts have snspped off r they presed in or threaded on my 99 l42 #8
I think you are confusing bolts and studs. Most German cars use bolts threaded into the spindle instead of lug nuts on studs, but the studs are not THREADED into the spindle, they are pressed in from behind. The way the statement was written was a bit confusing and took me a second and a double read to realize what was being said.
1996 INTERNATIONAL 4700 4X2 DUMP TRUCK (A51406)
1996 INTERNATIONAL...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2015 FREIGHTLINER...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
