Rebuild kit or replace: Ford 4500 Injector Pump Leaking thoughts?
   / Rebuild kit or replace: Ford 4500 Injector Pump Leaking thoughts? #1
Toreiron
MN
Ford 4500 TLB
Today my injector pump started leaking pretty bad. I’ll have to clean it up to try see where it is coming from. It is dripping pretty good so…replace or try a rebuild kit? You’ll have to excuse the dirty tractor. It’s new to me. Ran it four hours before it started leaking. Does anyone know the actual kit part number? Vintage 1973
   / Rebuild kit or replace: Ford 4500 Injector Pump Leaking thoughts? #2
Welcome to TBN. Have it rebuilt or DIY here is the kit 7135-110
   / Rebuild kit or replace: Ford 4500 Injector Pump Leaking thoughts? #3
Check your pump drive and grease it if it is still in good shape.
While you're at it, check the steering in the nose and grease the linkage
   / Rebuild kit or replace: Ford 4500 Injector Pump Leaking thoughts? #4
That’s a DPA pump previously made by CAV..
Delphi now..
& yes, the kit is 7135-110..
Depending on where it’s leaking, it’s either a diy or it’s not..
Delphi now..
It is leaking from the cover on the left and the banjo bolt on the side. The other two lines below are dripping but easily can be from the leaks above. It is the cover on the left that concerns me.
Thanks. I’ll try a kit and grease it up.
   / Rebuild kit or replace: Ford 4500 Injector Pump Leaking thoughts? #7
The cover is held on w 4 5/16 screws.
It’s sealed w a square cut oring found in the kit..
The banjo bolts that r leaking r sealed w a teflon crush washer, 1 on each side of the connector.. they 2 come in the kit..
Ur probably better off taking it off and sending it out…
Anyone have pros cons of using the Amazon rebuilt kits?
CATERPILLAR 305CR EXCAVATOR (A51242)
CATERPILLAR 305CR...
7 Shank V Ripper (A52128)
7 Shank V Ripper...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
(9) 8' Treated Posts (A50515)
(9) 8' Treated...
1996 Monon 45X96 Dry Van Trailer (A52128)
1996 Monon 45X96...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
