Recommendations for hand held electric pavement breaker please
   / Recommendations for hand held electric pavement breaker please #11
Can your tractor do it? 4” isn’t very thick. I’ve seen people get under a corner of it, lift it, drop it, repeat and break it up.
   / Recommendations for hand held electric pavement breaker please #12
100' of driveway wide enough for a car is a lot to break up with a hand held demo tool unless its crumbling to pieces already.
I've been happy with my Vevor; however, the case is terrible, made of paper thin ABS. I filled the voids in the shell of the case with StuffIt foam, after spraying some water inside the shell.
It cost less than my local 4 hour minimum rental.
Shop around, as the price varies and you can often score additional heads. I would tighten all the screws, oil / grease everything before using it and tighten the screws again after a few hours.
All the best,
Peter
Thanks, I'd been looking at the Vevor.
I have a 35# Makita that has served me well. Slower than a 60# breaker but a lot easier to handle.
Thanks
I hope to handle a lot of it with the tractor, but I need to be prepared to break out problem areas, versus getting stuck and having to drive to town for more equipment.
A lot of it is cracked and broken already. If I do it I plan on doing a section at a time, oerhaps 10x10.
   / Recommendations for hand held electric pavement breaker please #14
I don't know the brand name of the one I bought from Amazon, I think, but I suspect it came out of the same factory as many of the others. I only did a porch area much smaller than you're taking on. So I couldn't speak to its durability anyway.
The weight of the tool helps to break the concrete, but it's not fun moving it around. It could be helpful if you have a good two wheel cart to wheel it around between areas you're breaking.
   / Recommendations for hand held electric pavement breaker please #15
I can't get to a rental center in 90 minutes and I do my projects piecemeal. And the nearest rental place charges $400/day.
Ouch!
I probably paid maybe $100, but it was in the mid 80s.
That certainly changes the equation.
   / Recommendations for hand held electric pavement breaker please #16
I decided to take a gamble and buy one of these for the same reasons newbury said. Doesn't take much use to get your money's worth compared to some of these rental rates.
   / Recommendations for hand held electric pavement breaker please #17
I bought the bauer 70lb electric jackhammer from harbor freight and have been running that thing for years. Broke all the concrete around the pool so i could repour it. Did the old shed pad so I could dig out my shop. I busted up my parents back porch. I have probably 100 hours on that thing and it's gone through 4" to 12" with wire and rebar. One of my best investments.
I've nothing against renting tools I probably won't use again or that take a lot of upkeep.
But to have a good tool at the ready it's well worth the tradeoff of having to store it.
As I was checking things out for this thread I was reminded of setting Tposts and similar with a decent jack hammer. I'm also wanting to do a bunch of that.
And
thanks for that referral.
   / Recommendations for hand held electric pavement breaker please #19
Street saw, and lift panels with forks on a front end loader. Far less ruble, fast, and clean. If you get a good feel for it, you can pull whole 5ftx5ft squares out, sometimes intact, other times, maybe 2 or 3 pieces. Here is an electric one, that comes with the blade, for $210. I think the saw will be more useful than a electric breaking hammer.
Edit: I'm far from a safety guy, but maybe I've watched too many Silicosis training videos, run water, and where a mask/glasses. I've sawn plenty of concrete through the years without a mask, and only a water bottle with a nail hole in lid, and a helper squirting the blade to keep dust down, but not ideal.
   / Recommendations for hand held electric pavement breaker please #20
Also, the saw and lift approach, if you are repouring, requires less regrading and prep work for the next pour.
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
1999 Ford Econoline E-150 Cargo Van (A55852)
1999 Ford...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2017 Ford Fusion Sedan (A55853)
2017 Ford Fusion...
UNUSED FUTURE FT13 EXCAVATOR (A57192)
UNUSED FUTURE FT13...
Portable Restroom (A54865)
Portable Restroom...
