beenthere
Super Star Member
- Joined
 - Aug 16, 2001
- Messages
 - 18,589
- Location
 - Southern Wisconsin, USA
- Tractor
 - JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold)
Search should include the model numbers 4200, 4300, and 4400.  Same axle likely, but procedure likely the same.
for example:
					www.tractorbynet.com
			for example:
				Replacing MFWD spindle seal
Recently I had to dig into my MFWD on my JD4300 a bit in order to replace a leaky spindle seal. Talked about it here a bit. I thought I would snap some pictures and share it with you. Mind you I am not a certified mechanic and I am sure that I probably did some things the hard way but the...
